Thread: AC noise??
Results 1 to 6 of 6
  1. #1 AC noise??
    SE Level Member grandprix85's Avatar
    Milwaukee, WI
    My AC works fine (real cold) but when Im driving with my AC on, I will hear a low grinding noise. I only hear the noise when I have the AC on. What could be the problem?
    02 GP GT stock with tinted windows, 140K
  2. #2 Re: AC noise??
    maybe the bearing on the pully on the compressor?
    SMGPFC Member #10
  3. #3 Re: AC noise??
    SE Level Member tweak's Avatar
    Jul 2011
    nebraska
    sounds like your compressor clutch is grinding on the compressor. the reason it doesnt do it when the ac is on is beacuse the clutch kicks off when you turn on the ac it kicks out. you need ac tools to get the clutch off but you might be able to ajust it. you have to put a shim in behind the clutch.
  4. #4 Re: AC noise??
    Milwaukee, WI
    Thanks for the advice. Could I damage anything if I keep driving with the ac on?
  5. #5 Re: AC noise??
    no^
    SMGPFC Member #10
  6. #6 Re: AC noise??
    Milwaukee, WI
    no^
    Thanks. I rarely use the AC anyways since i live in Wisconsin so I wont rush and get it fixed.
  1. GTP Noise....
    By SuperCharged0nE in forum General Tech Discussion
    Last Post: 04-02-2010, 12:01 PM
  2. odd noise at 27 mph
    By rossscrappy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2010, 06:01 PM
  3. New noise..again..help?
    By BwolfGT in forum General Tech Discussion
    Last Post: 11-03-2009, 09:47 PM
  4. noise
    By roadwarrior1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-15-2009, 03:21 PM
  5. Odd noise, can someone help!!!
    By indybrad in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-23-2009, 02:06 PM
