Thread: loud knocking
Results 1 to 8 of 8
  1. #1 loud knocking
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    So I started driving my GTP. I got the tranny working but now I have a pretty loud knocking sound. I don't think it's a rod knock tho because it's intermittent..
    It doesn't matter what the engine temp is. It speeds up and slows with engine speed. Does it in all gears. P,N,D ect. It will be there one minute and go away the next. Always just as loud. Never gets quieter. It's there or it's not.
    I have an idea what I think it is but wanted some other opinions first. Thanks for any help
    I went NA when a whore left -$300 in my bank account.
  2. #2 Re: loud knocking
    busted flex plate?
  3. #3 Re: loud knocking
    Jan 2012
    Indianapolis
    That was my thought. I couldn't see anything when I turned the engine over but it's not very easy to see in there either.
    Does the engine have to be pulled to replace it or can it just be shifted to the side and replaced?
  4. #4 Re: loud knocking
    post a vid if you can, that will help a ton.
    should it be the flex, you can lift and separate and get to the bolts and swap it. leaving most everything hooked up to the engine. make sure you support the tranny so it dont drop or fall.
  5. #5 Re: loud knocking
    Jan 2012
    Indianapolis
    Hopefully I can get a video and post it Tomorrow. Is breaking flex plates common on 3800s
  6. #6 Re: loud knocking
    ive seen quite a few since joining here.
  7. #7 Re: loud knocking
    The Boss Iceman6669's Avatar
    Jun 2011
    L67 flex plates do break from time to time.
    2011 F-150 Yote powered
  8. #8 Re: loud knocking
    Jun 2011
    For reference here is what a busted flex plate sounds like.
    http://youtu.be/jeJU8EKQxLw
  1. Replies: 6
    Last Post: 10-24-2013, 11:21 PM
  2. Super loud screech after music plays somewhat loud.....
    By rizer in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 03:08 AM
  3. Knocking or tapping loud!
    By GotThatPower in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2012, 11:30 PM
  4. Top End Knocking?
    By cerdman in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-01-2010, 08:18 PM
  5. why am i knocking?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 08:32 PM
