Thread: Open cone air intake
Results 1 to 20 of 20
  1. #1 Open cone air intake
    Mar 2014
    Indiana
    Would it be ok to run open cone air intake on my 02 gtp? Or would that allow to much flow?
    2002 Fully Loaded GTP. Cat back exhaust and 20% window tint all the way around(Rollin in the dark). Soon to be CAI, headers, and high flow cat.
  2. #2 Re: Open cone air intake
    The Boss Iceman6669's Avatar
    Jun 2011
    Perfectly fine. And recommended
    2011 F-150 Yote powered
  3. #3 Re: Open cone air intake
    we all do it. search diy open cone. you can make your own for less then 40 bucks.
  4. #4 Re: Open cone air intake
    Mar 2014
    Indiana
    Can you run open cone year round and also will it attach directly to the throttle bodies?
  5. #5 Re: Open cone air intake
    Jun 2011
    That's mine... I run it year round in Michigan
  6. #6 Re: Open cone air intake
    Mar 2014
    Indiana
    Alright thanks and I noticed you don't have the top cover on is that just for the pic? Mine didn't come with the cover so I didn't know if I need to buy one. Btw I'm talking about the factory plastic that says 3800 series 2
  7. #7 Re: Open cone air intake
    Jun 2011
    Yea.. Mine hangs in the garage wall... Leave it off.
  8. #8 Re: Open cone air intake
    Mar 2014
    Indiana
    Alright thanks for the info btw what size and brand filter?
  9. #9 Re: Open cone air intake
    engine cover? who needs a cover? mine was long gone before i got my car.
    the way my open cone went.
  10. #10 Re: Open cone air intake
    Jun 2011
    I used a 9" specter filter iirc.
  11. #11 Re: Open cone air intake
    Mar 2014
    Indiana
    Scotty dog is that sensor in the elbow something extra or did iceman hide his
  12. #12 Re: Open cone air intake
    thats the ait sensor that is in the stock air tube, i drilled a hole and glued it in the hole.
    ice put his inside the filter i bet.
  13. #13 Re: Open cone air intake
    Mar 2014
    Indiana
    Probaly I haven't really looked at mine yet to get any ideas actually only started thinking about this an hour ago
  14. #14 Re: Open cone air intake
    you'll see it in the stock air tube. i put mine in the elbow at about the same spot as the stock tube.
  15. #15 Re: Open cone air intake
    Jun 2011
    I did have it tucked into the air filter for a while. But I was advised not to do that so now it chills tucked between the throttle cables.
  16. #16 Re: Open cone air intake
    Jun 2011
  17. #17 Re: Open cone air intake
    Mar 2014
    Indiana
    Ok... On a side note why is inside a no no.... I know its unrelated but in my MiniSprint which is Yamaha r1 powered I tucked it in the filter figuring it would get the true flow would it not be the same?
  18. #18 Re: Open cone air intake
    Jun 2011
    I was told that tucking it inside like I had could potentially skew the MAF readings .
  19. #19 Re: Open cone air intake
    Mar 2014
    Indiana
    Hmm could be so is putting it in the elbow a good idea then?
  20. #20 Re: Open cone air intake
    Having it directly on the throttle body will skew maf readings.
    Same with sticking it inside the air filter, it'll just get moved round in there and maybe sucked up against the maf screen.
    Get a coupler before the filter, you do want some straight flowing tubing before the screen.
  1. Open Cone Intake.
    By NinetyEightGTP in forum General Tech Discussion
    Last Post: 02-04-2013, 07:26 AM
  2. Open Cone Intake
    By demetriuslopez in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-25-2010, 11:11 AM
  3. Open cone intake
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 08-11-2010, 05:01 PM
