https://www.youtube.com/watch?v=NFt4...e_gdata_player
recent lim job done headers and 3800pcm 180 stat I think its the flex on the headers any suggestions?
Down pipe and let me see if I can reupload it
Need to go on YT video settings and set it to everyone with no comments.Then we can watch. just sayin...
Video is public now my bad uploaded it from my Droid phone.
Did you check the harmonic balancer like I said?
I have yet to take a look working all weekend 12but hours but Monday if I can ill start taking the belts off and etc
That's def not the flex. Sounds like top end or flex plate maybe? Pull the belts off and see if it still makes the noise.
I'm assuming it wasn't making this noise before you did the LIM gasket. Did it make this noise immediately after the work was done? Did you reuse the stock rocker arm bolts? Is your oil light coming on at idle? Does the noise follow increased RPM?
If removing the belt doesn't make a difference I would check the rockers or the rest of the valve train. I hope it's just a tensioner or the balancer like slick2500 says.
Noise increase with RPMS?
Did you change the oil twice after doing said LIM job?
To me it almost sounds bottem end related.
Metal sparkles in the oil at all?
And I guess it wouldnt hurt to take the belts off to see if anything changes.
The noise started after I put 11miles on the car after I did the l.I.m so I have not done a second oil change. It does get louder with more rpms and won't shift right if I get on it a little. I'm going to take all the belts off and crank it over to see if any thing changes
Well I checked the oil and it looks like a Chocolate milk shake. I never did open the valve covers. So I'm thinking the engine is shot
Every time I hear or read this I get sick in the stomach for the person involved. You probably spun a bearing or two. You got your work cut out for ya now. Maybe you could drop the pan and check the rod bearings. It's not that hard if you have a good set of metric ratchet wrenches (15mm). An oil pressure test couldn't hurt either.
depending on where you are in ohio i have a short block l67 in my garage i'd let go of cheap to help you out.
