Thread: max revs on stock bottom end?
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #1 Re: max revs on stock bottom end?
    Feb 2013
    37.295091, -121.930053
    a blown tranny?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  2. #2 Re: max revs on stock bottom end?
    The Boss Iceman6669's Avatar
    Jun 2011
    With the proper springs and ****Z.
    2011 F-150 Yote powered
  3. #3 Re: max revs on stock bottom end?
    Jan 2013
    Australia
    valve train shouldnt be a problem... 130lbs springs, modded retainers and valve stem seals, double row timing chain. And my transmission is fully built... has been putting up with over 400 ft/lbs at 2800 rpm since i got the a2a cooler last year
  4. #4 Re: max revs on stock bottom end?
    Jan 2013
    Australia
    who gives a **** lol... these motors have been around for 50 years in their basic design... and they're pretty much bullet proof.
    Just not balanced very well from factory i hear
  5. #5 Re: max revs on stock bottom end?
    hangover park IL
    Quote Originally Posted by Schwuppes View Post
    the balance issue is a mater of 3rd and 4th order harmonics from the close coupled rocking inherent in a 90* bank angle v6 (the sbc v6 also suffered from this)
    ....this extra NVH is removed by a more inherently stable 60* bank angle v6 as are ALL of gm's current v6 offerings
    ~James~ Psychotic Gearhead
  6. #6 Re: max revs on stock bottom end?
    Jun 2011
  7. #7 Re: max revs on stock bottom end?
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Never said you could swap parts from a chevy to a 3.8. They have the 90° v6 design exactly like the chevy. Not like buick They had a wide designed intake.
    The wide intake was actually a pontiac design.
    And trolling I am not. I didn't say the diesel was designed by izuzu. Try reading for a change. The duramax diesel was designed by izuzu. Troll on.
    His name was Rudolf diesel by the way.
    Sent from Not so smart smartphone
  8. #8 Re: max revs on stock bottom end?
    Dec 2012
    troll land
    Ok then ANY chevy design is actually a caddy/olds design as they camw out in 1949 and the 265 chevy was based off them, same engineer in fact. And i never claimed the duramax was designed by chevy, so mebbe YOU should try reading for a change
    Quote Originally Posted by Twizted 1 View Post
  9. #9 Re: max revs on stock bottom end?
    Jul 2013
    Summertown Tn
    Thanks ice. Hmm Learned something new.
    GM has owned it since 1962 and sold it to kaizer/jeep in 1967.
  10. #10 Re: max revs on stock bottom end?
    Jul 2013
    Summertown Tn
    Ok you got me on the diesel comment, I misread your comment.
    But, in 1908 david buick changed the name of his company to general motors and it has been since. So EVERY motor that has been in a buick since that time has been a GM engine. As with GMC, chevy, and all of its subsidiaries. They are all GM.
    Sorry for the threadjack.
  11. #11 Re: max revs on stock bottom end?
    Florida
    I've got mine setup to shift at 6250, actually shifts closer to 6500.
    Stock bottom end I wouldn't run much more than that on a daily basis.
    All else fails, get another motor and balance the entire rotating assembly and rev the **** out of it.
  12. #12 Re: max revs on stock bottom end?
    Jan 2013
    Australia
    i think I'll just tell him to shift at 6200rpm... limit at 6500. That sounds like a good compromise.... mine currently makes it peak power at 5200 rpm... so an extra 1000+ revs or so will do me nicely
  13. #13 Re: max revs on stock bottom end?
    SE Level Member pontiac4lifesc's Avatar
    Mar 2012
    Winona, MN
    they usually rev a little higher than the set point. i have mine set at 6200 and revs just a tad higher and other guys have said they have seen 100 to 150rmps more than the set point.
  14. #14 Re: max revs on stock bottom end?
    Jan 2013
    Australia
    what cam are you running mate?
  15. #15 Re: max revs on stock bottom end?
    Mar 2012
    Winona, MN
    im running xpz i aslo have a sfi balancer.
  1. Replacing L67 bottom end for L26 bottom end
    By OcalaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2013, 06:05 PM
  2. high revs as i start car
    By Jrs1987 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2011, 06:28 PM
  3. Revs go up/not changing gears?
    By SUGAR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2011, 11:07 PM
  4. trans revs out
    By kbmukdk2316 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 11-01-2010, 02:50 PM
  5. bottom swap, or how i learned to rebuild the bottom end completely
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 03:37 AM
