Thread: 255 Walbro pump install on Non Venturi 02 GTP
Results 1 to 13 of 13
  1. #1 255 Walbro pump install on Non Venturi 02 GTP
    Donating Users timboku's Avatar
    Montgomery, IL
    Need some help. Got a Walbro pump from intense. Putting it into a non venture 02 gtp. What modifications need to be made to make the pump fit? The original pump has two nozzles on the bottom and the walbro has one big one??? Been searching but cannot find any write ups. the instructions on intense are for a 1998 and the 02 is different. Help got the car torn apart.
    Thanks!!!
  2. #2 Re: 255 Walbro pump install on Non Venturi 02 GTP
    The Boss Iceman6669's Avatar
    Jun 2011
    Should be just a drop in.
    2011 F-150 Yote powered
  3. #3 Re: 255 Walbro pump install on Non Venturi 02 GTP
    Montgomery, IL
    Thats what i thought but it is not...The instructions on intense website are for a venturi pump. I have a non venturi so in researching there needs to be some modification to the canister or something but I cannot locate what the modification is.
    IMG_20140125_141918_zpswh2fdg8x.jpgIMG_20140125_14183_edit_1390681127334_zps9rxsb7mf.jpg
  4. #4 Re: 255 Walbro pump install on Non Venturi 02 GTP
    Jun 2011
    I did the Racetronix on mine which is a venturi version of the Walbro and it was a drop in once I had a venturi canister
  5. #5 Re: 255 Walbro pump install on Non Venturi 02 GTP
    Montgomery, IL
    They went to all non venture in late 2000 so all 01 and up gtps are non venture.
  6. #6 Re: 255 Walbro pump install on Non Venturi 02 GTP
    Jun 2011
    Right i know that.
  7. #7 Re: 255 Walbro pump install on Non Venturi 02 GTP
    Montgomery, IL
    So there is no way to do it without a venturi canister or can you mod the current one? trying not to go to the junkyard in the cold and snow..ugh.
  8. #8 Re: 255 Walbro pump install on Non Venturi 02 GTP
    Jun 2011
    Your car and pump in a NON-VENTURI. it is just a drop in. Like the pick up on the bottom of the pump with the plunger on the bottom of the canister.
  9. #9 Re: 255 Walbro pump install on Non Venturi 02 GTP
    Montgomery, IL
    so even if the holes do not line up in the canister it is fine? I get what your saying and makes sense but doesn't that effect the fuel pick up? How does the canister fill when the gas level gets below the canister?
  10. #10 Re: 255 Walbro pump install on Non Venturi 02 GTP
    Montgomery, IL
    Ok I answered my own question and I.am over thinking this..use to working with a venturi pump...thanks for your help..lol.canister just fills up and pump draws from there..makes sense.
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  11. #11 Re: 255 Walbro pump install on Non Venturi 02 GTP
    Jun 2011
    Bingo.
  12. #12 Re: 255 Walbro pump install on Non Venturi 02 GTP
    Montgomery, IL
    Pump in and running..thanks again!
  13. #13 Re: 255 Walbro pump install on Non Venturi 02 GTP
    Jun 2011
    Not a problem.
  1. walbro 255 fuel pump
    By 00grandprixgtp in forum Wanted To Buy - Parts
    Last Post: 12-22-2013, 12:05 AM
  2. I put a non venturi pump in a venturi canister.
    By Frosty in forum General Tech Discussion
    Last Post: 08-14-2013, 12:52 AM
  3. Venturi Pump
    By djrepoman in forum General Tech Discussion
    Last Post: 03-06-2013, 10:13 PM
  4. walbro pump and/or hotwire mod
    By usetaboost in forum General Tech Discussion
    Last Post: 12-31-2012, 07:21 PM
  5. Venturi modification of Walbro 255LPH
    By Lysander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2009, 01:49 PM
