Thread: Throttle Body vacuum connector
Results 1 to 20 of 20
  1. #1 Throttle Body vacuum connector
    SE Level Member yekimmrt's Avatar
    raleigh, nc
    Does anybody have a PN for the U shaped step down vacuum connector coming off of the throttle body or the similar one going to the EVAP, I think? Mine crumbled after a TB cleaning and I've got it rigged up with a T, vacuum cap, and some 3/8 fuel line. I'll be replacing my lifters in the coming months and I'd like to put new vacuum lines in to replace all the rigged up ones I have, but I can't find those particular connectors anywhere. Thanks! 2001 GTP btw.
  2. #2 Re: Throttle Body vacuum connector
    A dealership is the only place that will have that line.
    Most just make there own vacuum lines to make it simple.
  3. #3 Re: Throttle Body vacuum connector
    like this.
  4. #4 Re: Throttle Body vacuum connector
    Feb 2013
    37.295091, -121.930053
    Haha I went to oreillys and told them I need a hose the same length paid $5 and slapped it on the car
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Throttle Body vacuum connector
    I live here. DirtDog's Avatar
    Jun 2012
    Gmpartsdirect would have it
  6. #6 Re: Throttle Body vacuum connector
    raleigh, nc
    I was browsing GMparts, couldn't find it... thought a PN might make it easier. I've got a 4 dollar job on there now, glad to find out I'm not alone.
  7. #7 Re: Throttle Body vacuum connector
    in my pic is 50 cents.
  8. #8 Re: Throttle Body vacuum connector
    Jun 2012
    Call dealer...ask for PN. Bam
  9. #9 Re: Throttle Body vacuum connector
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    I got mine from the dealership for $16.
    I had to have them pull up a parts explosion, then pointed it out to them.
    Sent from Not so smart smartphone
  10. #10 Re: Throttle Body vacuum connector
    50 cents. why pay 16 bucks for the same thing?
  11. #11 Re: Throttle Body vacuum connector
    Jul 2013
    Summertown Tn
    Because I was narrowing down leaks and when you have 3-4 pieces of rubber tubing put together there's just that many more places to have a leak.
  12. #12 Re: Throttle Body vacuum connector
    it dont leak. been there for over a year now. its only 2 pieces, a fat one on the TB to a thinner one pushed inside it, then to the factory plastic line.
  13. #13 Re: Throttle Body vacuum connector
    Jul 2013
    Summertown Tn
    easy grasshopper. Never said it did.
    I just didn't want to add another place to have a leak in these damn demons.
  14. #14 Re: Throttle Body vacuum connector
    idk, in my book 50 cents wins over 16 bucks at a ass raping dealer.
  15. #15 Re: Throttle Body vacuum connector
    Jul 2013
    Summertown Tn
    I understand. But I was pulling my damn hair out trying to get to the bottom of a lean code. So I went back with everything the way it was meant to be.
    Solved my issue. So from now on I'll put the factory spec lines for the vacuum system.
  16. #16 Re: Throttle Body vacuum connector
    Sep 2011
    Canada
    Plastic isn't any better than rubber!
  17. #17 Re: Throttle Body vacuum connector
    Jul 2013
    Summertown Tn
    Ok. And your point is?
    The OP is looking for the stock replacement. So was I.
    If you want to use rubber, use it.
    Different strokes for different folks.
  18. #18 Re: Throttle Body vacuum connector
    raleigh, nc
    Update...my rigged up autozone T's with a cap, 3/8 fuel and 7/16 vacuum lines do, in fact, leak. Found it with carb cleaner. Back to the drawing board.
  19. #19 Re: Throttle Body vacuum connector
    thats because fuel line is not vac line, buy 3/8 vac tube.
  20. #20 Re: Throttle Body vacuum connector
    raleigh, nc
    The fuel line actually worked out ok, the leak was on the cap of the tee. I just shoved the other two pieces together, it's good now.
  1. Throttle Body to vacuum line connector '99 Grand Prix (Also, erratic idle issue)
    By killswitch83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-05-2012, 05:52 PM
  2. N* throttle body
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2009, 01:41 PM
