Thread: LIM Gasket
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
  1. #1 LIM Gasket
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    Today I decided to stop procrastinating and to man up and tackle this job and I think the hardest part was the coolant elbows... Anyways I'm down in the intake and I need some tips on cleaning it out there's a lot of mushy gunk in here. Also is there anything I should do while I'm down here? Also here's some pictures
  2. #2 Re: LIM Gasket
    St. Louis
    I'd say shop vac it. You need to clean out as much of that junk as possible. Once back together you will need to do a flush of the cooling system, at least once, possibly more. Until the water comes out clear then you still have crap in the system. I'd be willing to bet the inside of the rad. is clogged up as well.
    And backflush the heater core as well. Don't flush in the same direction as the coolant flow or it could clog up worse. Backflush should clean out junk better from my experiences. And no, I don't remember which tube is the inlet on the core, lol... Been too long.
  3. #3 Re: LIM Gasket
    Feb 2013
    37.295091, -121.930053
    umm when was the last time you washed your engine? also too timing chain and hoses, sensors along with water pump, and for some fun a new cam.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: LIM Gasket
    gardner,mass
    that is bad
    1) shop vac up as much as you can
    2)clean up the mating surfaces with a razor and shop vac the rest of that **** up
    3) clean intake with carb cleaner the best you can and i also suggest taking off the tb and cleaning that right now aswell
    4) put on new lim gaskets and make sure you apply a dot of rtv inbetween where the gaskets meet in the corners
    5) put on low intake and torque it down
    6) put the rest together, coolant elbows plenum, alternator, belts, fuel rails, ect
    7) put some coolant flush ( can also use dish soap) in the rad and fill with water.
    8) new cheap oil
    9) prime the gas by turning the key to on then off and on a couple times befor starting it
    10) flush the cooling system over and over with fresh water by letting the car get up to operating temp and turning the blower on high heat, then shutting it off, letting it cool then draining. Rinse and repeat but be careful you can severly burn yourself if you try to drain it while its hot
    11) after you flush it and fill it with fresh global 50/50 mix and a new thermostat drain the oil and put in some more new cheap oil
    12)Go for a drive and see how she is then change the oil again after with good oil
    Edit: oh ya you need injector orings too. I use a little spit to get them seated
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  5. #5 Re: LIM Gasket
    gardner,mass
    Oh yea and afters its all said and done. Get some ****ing super clean and clean that bay.
  6. #6 Re: LIM Gasket
    you went the hard way with the injectors, you should hav eleft them in the rail, unbolted the rail, and pulled them out of the heads.
    that being said, pull the injectors out of the heads, put them back in the rail, get a box of Q tips and brake cleaner to clean the injector holes.
    use a razor to clean and scrap the crap off the lim or heads, same for the sc and lim mating areas. wipe every thing down, gasket matting surfaces with with brake cleaner.
    clean that crap out of your coolant ports dont let it fall into the lim valley, lay rags under the ports.
    do flush the cooling system and core, you got all sorts of dex sludge in there, and the rad cap, or buy a new cap they cost 3 to 5 bucks.
    you may want to replace the vac lines and T's because most of the time the ends break when doing the lim job. due to taking the lines off and on.
  7. #7 Re: LIM Gasket
    Oct 2012
    Philadelphia
    Quote Originally Posted by FordMan77 View Post
    The rad was leaking so I bought a new one today along with a new condenser, I'm still gonna flush it tho, this gunk is everywhere
    Ive bought the car a month ago and haven't had a chance to get it detailed I plan on getting it pressure washed after this is all over..
  8. #8 Re: LIM Gasket
    i always wash a engine before i work on it, this way you working environment is much cleaner.
  9. #9 Re: LIM Gasket
    Feb 2013
    umm scotty the injectors plug into the intake not the heads bro
  10. #10 Re: LIM Gasket
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    make sure you assemble everything correctly, i went through three motors which i concluded to be improper intake assembly lol still dont know what i did wrong other then my torque wrench may have been off and i didn't tighten the bolts enough so idk
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  11. #11 Re: LIM Gasket
    Feb 2013
    Quote Originally Posted by BlackGT97 View Post
    wrong tighting order more than likely.
  12. #12 Re: LIM Gasket
    ummm yeah on a n/a engine,
    supercharged engine the injectors go in the heads, go look at his pics again.
  13. #13 Re: LIM Gasket
    Feb 2013
    well mine were in the intake lol
  14. #14 Re: LIM Gasket
    Jul 2011
    Michigan
    not on the sc 3800
  15. #15 Re: LIM Gasket
    Jul 2011
    Michigan
    nah i dont think that was it either
  16. #16 Re: LIM Gasket
    you want to set the lim on the engine, give it a few hits with your fist, then get the bolts to line up, then work in a X pattern center out, just making each bolt snug, keep doing this till the lim sits flat to the heads and block. then torque them down. when you get back to the first bolt, it will be loose again, so keep going around the lim bolts till they are all snug.
  17. #17 Re: LIM Gasket
    Jul 2011
    Michigan
    Do you use a torque wrench or just go by feel?
  18. #18 Re: LIM Gasket
    Jul 2011
    Michigan
    i have talked to some people who torque them down pretty good, way over 11 pounds
  19. #19 Re: LIM Gasket
    i used a t wrench in the end, but just snug them till all the bolts are snug, and the lim is flush. if you dont have a t wrench, a lot of people do them with out one, just make then good and snug, then a 1/4 turn more, be careful not to make them to tight or they snap. same goes for the sc bolts.
    dont forget to coat the lim bolts with thread sealant too. clean the bolts up nice, then re apply the sealant.
    iirc i went 12 on the lim, and 17 on the sc bolts. something like that.
  20. #20 Re: LIM Gasket
    Oct 2012
    Philadelphia
    I can't get this injector off
  1. LIM gasket or Head Gasket?
    By Fahrenheit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2013, 06:12 AM
  2. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  3. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  4. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  5. gasket kit
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 04:39 PM
