do both fans come on when you turn the a/c on? and if you were to drive with the a/c on, does it still get hot? because the a/c turns the fans on and keeps them both on.
bad temp sensor, or bad fans?
it truly seems like you've hit all bases.
AC not working but fans come on when temp goes too high. I replaced coolant temp sensor when i did the LIM. I get lots of heat but will check hoses. Weird part is that i get no coolant out of the bleeder when i hold rpms up
