Thread: Overheating issue - absolutely stumped (Done almost everything)
Page 4 of 4 FirstFirst ... 234
Results 61 to 74 of 74
  1. #61 Re: Overheating issue - absolutely stumped (Done almost everything)
    Cambridge, Ontario Canada
    The rad I have doesn't have a coolant temp sensor plug. But coolant was topped up. I still can't believe the running temp. It was 21 celsius out today and the car was idling at a light at 218 degrees. So I get home and decide to crack the bleeder & absolutely nothing is coming out. Not a drop like the coolant isn't circulating. wtf... Also the rad cap remains moderately warm at best although temp says 210-218... something is up!
    2005 E55 - stock
  2. #62 Re: Overheating issue - absolutely stumped (Done almost everything)
    4 pages deep im guessing you changed the t stat and or the water pump at some point?
  3. #63 Re: Overheating issue - absolutely stumped (Done almost everything)
    Apr 2009
    Fort Worth TX
    One thing I don't like about these cars is the coolant passages in the head gaskets. The cooling jackets in the engine are huge but the head gasket passage is about a 3mm hole. If these get clogged you'll see what you're seeing. I believe GM did this to achieve a certain coolant flow rate throughout the engine.
  4. #64 Re: Overheating issue - absolutely stumped (Done almost everything)
    Georgia
    I 've been using the Napa Superstat (by Stant) for years without any problems. These are high quality thermostats. The part # for the correct 180 stat is 531080.
  5. #65 Re: Overheating issue - absolutely stumped (Done almost everything)
    Water pump and t stat replaced. T stat has been replaced a few times with different brands and it has 6 holes drilled. Tearing motor down to check out coolant passage would suck huge ass
    2005 E55 - stock
  6. #66 Re: Overheating issue - absolutely stumped (Done almost everything)
    HUDSON
    The only thing the "hole in the t-stat" mod does is let any air that is trapped in the block escape when the engine starts. If your temperature gauge reads above the t-stat opening point, and the upper radiator hose is not hot, it is possible that the t-stat is not opening, or the water level is low.
  7. #67 Re: Overheating issue - absolutely stumped (Done almost everything)
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by Elite6 View Post
    LOL
    Last resort man.
    Buffalo
    Radiator is probably toast. It's not removing heat efficiently.
    Or you have air in system.
    You already have what, new t stat and water pump. So not much left
  9. #69 Re: Overheating issue - absolutely stumped (Done almost everything)
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by crazyguy03 View Post
    He already tried radiator.
  10. #70 Re: Overheating issue - absolutely stumped (Done almost everything)
    SE Level Member chrisLB's Avatar
    Nov 2009
    canada
    i would go to a shop and ask them to use a temperature gun and see if youre really running hot, most will do it for free then youll know for sure.. if you are and after all the parts you have put in maybe a crack in the head?
  11. #71 Re: Overheating issue - absolutely stumped (Done almost everything)
    Nov 2009
    canada
    ive had water pumps that have failed in the first week.. the still move some coolent but not like they should so dont count that out even though you replaced it but you had this problem before that so i doubt its that.
    Buffalo
    Soo. Pay $3 at the junkyard. Check out a new coolant temp sensor ?
  13. #73 Re: Overheating issue - absolutely stumped (Done almost everything)
    Georgia
    Oxalic acid flush, created something when neutralized.... Interesting thread on doing an acid flush. Just finished doing one. I picked up a 1 1/4 steel barbed coupler and installed in the upper radiator hose, Makes for a quick drain hook up with a corrugated hose, both from Home Depot. I took an old 195f stat and drilled four 3/32 holes in it and installed. Filling radiator with a garden hose with engine running and a drain hose connected to upper radiator hose. During the acid flush with big fan fuse out, I was able to get up to 210-220F. Ran the acid for about 1 hour, then flushed with water. Flushed with neutralizer(baking soda) and once more with water.
  14. #74 Re: Overheating issue - absolutely stumped (Done almost everything)
    Mar 2012
    lakewood
    Try a brand new radiator, ditch the used one
  1. Stumped on cooling fan issue
    By indy99gpgt in forum General Tech Discussion
    Last Post: 07-01-2012, 10:57 AM
  2. Overheating issue
    By Below Average Joe in forum General Tech Discussion
    Last Post: 11-13-2011, 11:42 PM
  3. overheating issue
    By alreadytooken in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-29-2011, 10:28 PM
  4. 96 grand prix overheating issue
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-10-2009, 12:37 AM
  5. overheating issue
    By doc7000 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2008, 01:18 AM
