The tow truck is on the way so I will just have to double check it when I get home. But I think that he pulled the correct one because he was having to pull the two fuses just to the left of it to get a grip on the relay.
Alldata shows the fuse block as having the same layout as the picture is from fivefingerdeathpunch.
I also have a PCM that I got off ebay. Should I try plugging that in to see if maybe the PCM is shutting it down?
