Thread: silly maf, bill, blue, bio, help can i haz?
Results 1 to 8 of 8
  1. #1 silly maf, bill, blue, bio, help can i haz?
    Bunnell, FL
    so i did the headers, got the o2 extension and sim a week later
    cleared the codes and the maf low popped up
    so waited 2 weeks got a re-man unit, the old one broke while it was being removed, so cleared the codes re-started the car and low popped right back up
    i havent checked to see it i mixed up the tps and maf, but the car runs fine and idles fine
    i also had the egr removed and the "cold start" vacuum line in my 97 is disconnected
    do i need a new maf, a tune to correct something, or wtf is going on?
    I'm a Sex Offender
  2. #2 Re: silly maf, bill, blue, bio, help can i haz?
    check the wires on the plug for the maf, being a 97 they could be cracked or missing insulation, and cause a low voltage.
    i had to replace my pig tail on my 98. it was all torn up.
  3. #3 Re: silly maf, bill, blue, bio, help can i haz?
    Out West
    Check your ground. I had this problem when replacing the coolant elbows, i somehow forgot the ground so i just made a new ground.
    Whine with your Cheese?
  4. #4 Re: silly maf, bill, blue, bio, help can i haz?
    Florida
    do you have a scan gauge? if your trims were off before the headers, you could be over the limit and the car thinks the maf is wrong.... what are your trims now? if they are -23 this might be the issue
  5. #5 Re: silly maf, bill, blue, bio, help can i haz?
    If our name isn in the title are we not allowed to help?
  6. #6 Re: silly maf, bill, blue, bio, help can i haz?
    Omaha, NE
    Quote Originally Posted by gtpsleeper View Post
    This.
    Remanufactured MAFs are notorious for problems. I'd reccomend a new one personally, but my name wasn't listed in the title, so I'm probably wrong.
  7. #7 Re: silly maf, bill, blue, bio, help can i haz?
    This.
    THIS...
  8. #8 Re: silly maf, bill, blue, bio, help can i haz?
    Bunnell, FL
    i'll check the trim's tomorrow on the way to work
    but i can get the aeroforce to read the low trim only the high
    and i'll see if i cant get advanced to give me a new one vs the reman
    I'm a Sex Offender
  1. Bill stole my bear
    Last Post: 12-01-2014, 12:16 PM
  2. Bill Gates and saving...
    Last Post: 08-15-2011, 06:08 PM
  3. Bill....
    Last Post: 08-09-2011, 09:14 AM
  4. 4 wheels for a bill + shippin??
    By TexasSteve58 in forum Tires & Wheels
    Last Post: 05-13-2010, 07:16 PM
