Thread: car quit, restarts quits - HELP
Results 1 to 20 of 47
  1. #1 Re: car quit, restarts quits - HELP
    I'd say either the maf or the fuel pump resistor. The symptoms point straight to the resistor.
    If you take the fuel pump speed relay out of the underhood fuse block and then bend either pin 85 or 86 (the one that won't get in the way when you put the relay back in) that'll put you in high speed pump mode and the car will likely run fine. If so..it's the resistor and you can motor on w/o worries for quite some time.
    I've had my pin bent for ......5 months now..lol
  2. #2 Re: car quit, restarts quits - HELP
    Donating Users
    Aug 2011
    Lowell, IN
    Okay great. Now I have to "relay" this to my son and get him to understand it. How can I get him to understand it if I don't understand it? LOL
    Where are the great pictures Bill of the relay and the bent pin that you always provide?
    Seriously, I am not quite understanding the pin bending thing. I know to go to the junction box and find the fule pump speed relay and pull it out. But are the pins numbered?
    It's not you, it's me. I just have never done this one before so explaining it to my son my be difficult. Is it much more self explanatory once you pull the relay?
    '99 GTP coupe, bone stock because I have enough troubles already.
  3. #3 Re: car quit, restarts quits - HELP
    bottom left, when looking at it from the top
  4. #4 Re: car quit, restarts quits - HELP
    Donating Users
    Aug 2011
    Lowell, IN
    Man, Thank you guys for the great info! Even if this isn't it you have all done a fine job, going above and beyond the call!
  5. #5 Re: car quit, restarts quits - HELP
    That's the pic .. I searched and couldn't find it... it's in an oddly named thread.
  6. #6 Re: car quit, restarts quits - HELP
    Wow..I searched and didn't check my pb account. Went to copy in the pic FFDP posted and found the pic of my Regals fusebox.....with pin bent. Keep in mind, my pic is a slightly different fuse box because it's a Regal. Have him look at the fuse box cover to ensure he's on the fuel pump speed relay. That's the key.
  7. #7 Re: car quit, restarts quits - HELP
    Donating Users
    Aug 2011
    Lowell, IN
    The tow truck is on the way so I will just have to double check it when I get home. But I think that he pulled the correct one because he was having to pull the two fuses just to the left of it to get a grip on the relay.
    Alldata shows the fuse block as having the same layout as the picture is from fivefingerdeathpunch.
    I also have a PCM that I got off ebay. Should I try plugging that in to see if maybe the PCM is shutting it down?
  8. #8 Re: car quit, restarts quits - HELP
    Donating Users
    Aug 2011
    Lowell, IN
    We tried both of the things mentioned and they did not work. I am going to have it towed home so I can mess with it.
    While my son was doing the "testing" the guy from the oil change place came over and said it sounded like a coil pack or something. The car will not start now.
    As a side note, I have been have troubles with the DIC reading all zeros and the ABS light being on along with the TCS off light being on. I had suspected the ignition switch which I bought but have not put on yet. Do you think that it could be related? Could the switch be bad and cause the theft deterant system to shut the car down?
    What would be next on your items to check?
    The oil light comes on after the car quits but I think that is normal. The car sounds normal when it does start but quits right away. There were no sounds or lights other than the lights I mentioned.
    I did put this motor in 6 weeks ago from a junk yard. It has been running good. At that time I put new plugs and wires on it as well as changing all gaskets. I have another set of coil pack from the original motor that I could try. What do you guys think?
  1. Engine quits during spirited acceleration
    By Jedi 41 in forum 5.3L V8 (LS4)
    Last Post: 01-13-2012, 01:42 PM
  2. Tac quits and goes to zero/trac off light comes on
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2012, 05:37 PM
  3. Car quits while running frequently
    By jokyfo in forum General Tech Discussion
    Last Post: 04-21-2011, 11:16 PM
  4. Engine Quits After 30-45 Minutes
    By DanGale in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-25-2010, 01:22 AM
  5. so i think im calling it quits
    By QwikGT in forum Off Topic Discussion
    Last Post: 04-28-2009, 11:36 PM
