Thread: car quit, restarts quits - HELP
Results 1 to 20 of 47
  1. #1 Re: car quit, restarts quits - HELP
    bg ky
    it is the crank sensor
  2. #2 Re: car quit, restarts quits - HELP
    Donating Users
    Aug 2011
    Lowell, IN
    The tow truck brought it home. once I got home from work I went out to see if my son had done the relay thing correctly amd it was perfect. So I tried starting it and it started right up. It idled for a 30 seconds or so then since the tow truck put it in the driveway backwards, I decided to turn it around to put it in the garage. I pulled it forward then backward then turned it sideways in the driveway and it quite. It started back up and I backed it up a little bit then it quit. It did not want to start then.
    I went in the house for a second then came back out and tried it again. it started just for a second or so then quit.
    When it was running it ran fine and smooth. When it quit it was just smooth like it ran out of fuel.
    Thoughts?
    '99 GTP coupe, bone stock because I have enough troubles already.
  3. #3 Re: car quit, restarts quits - HELP
    GTP Level Member
    Oct 2011
    Raleigh, NC
    out of gas
    1997 Red GTP 182000 miles stock
  4. #4 Re: car quit, restarts quits - HELP
    is the check engine light on?
    could try unplugging the maf, see if it runs, if so you need a new maf.
  1. Engine quits during spirited acceleration
    By Jedi 41 in forum 5.3L V8 (LS4)
    Last Post: 01-13-2012, 01:42 PM
  2. Tac quits and goes to zero/trac off light comes on
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2012, 05:37 PM
  3. Car quits while running frequently
    By jokyfo in forum General Tech Discussion
    Last Post: 04-21-2011, 11:16 PM
  4. Engine Quits After 30-45 Minutes
    By DanGale in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-25-2010, 01:22 AM
  5. so i think im calling it quits
    By QwikGT in forum Off Topic Discussion
    Last Post: 04-28-2009, 11:36 PM
