We tried both of the things mentioned and they did not work. I am going to have it towed home so I can mess with it.
While my son was doing the "testing" the guy from the oil change place came over and said it sounded like a coil pack or something. The car will not start now.
As a side note, I have been have troubles with the DIC reading all zeros and the ABS light being on along with the TCS off light being on. I had suspected the ignition switch which I bought but have not put on yet. Do you think that it could be related? Could the switch be bad and cause the theft deterant system to shut the car down?
What would be next on your items to check?
The oil light comes on after the car quits but I think that is normal. The car sounds normal when it does start but quits right away. There were no sounds or lights other than the lights I mentioned.
I did put this motor in 6 weeks ago from a junk yard. It has been running good. At that time I put new plugs and wires on it as well as changing all gaskets. I have another set of coil pack from the original motor that I could try. What do you guys think?
