Thread: Won't start after cam install
Page 10 of 23 FirstFirst ... 8910111220 ... LastLast
Results 181 to 200 of 448
  1. #181 Re: Won't start after cam install
    Grand Rapids, MI
    hm, did you replace with a new balancer?? perhaps that is your cause.
    if not i'd check the ignition system out.
  2. #182 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    It's a brand new balancer. What do I check with the ICM? This install has been a f*cking nightmare. Ugh.
  3. #183 Re: Won't start after cam install
    Grand Rapids, MI
    if i'm not mistaken, a parts store can check ICM right around where they test for starters, alternators, etc.
  4. #184 Re: Won't start after cam install
    I have no idea what to do. My ICM was fine before pulling my motor. My harmonic balancer is new. What would cause fuel trims to be at zero all the time? Stuck in open loop? That just doesn't make sense though. And the car is surging bad at higher RPM's.
  5. #185 Re: Won't start after cam install
    Vacuum leak possibly...then again I thought a vacuum leak would spike the trims at 16.4...
  6. #186 Re: Won't start after cam install
    Checked for vacuum leaks. Couldn't find one.
  7. #187 Re: Won't start after cam install
    Could the tune throw the car off this much? I haven't had a chance to fully tune it. I just added a bit of fuel everywhere, upped the shift points by 100 RPM, and increased idle speed a bit.
  8. #188 Re: Won't start after cam install
    Nov 2010
    Atlanta Ga
    If the engine isn't hot enough or your pre cat o2 isn't working it will never go into closed loop.
  9. #189 Re: Won't start after cam install
    Quote Originally Posted by kevins View Post
    If my O2 values are reading on my scanner, that confirms my front O2 sensor is working, right?
  10. #190 Re: Won't start after cam install
  11. #191 Re: Won't start after cam install
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    fuel trims at zero occur when its relearning(after the batts been disconnected) or you did a relearn Via HPT. drive it around a bit see if it starts jumping around.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  12. #192 Re: Won't start after cam install
    I'll check tonight.
  13. #193 Re: Won't start after cam install
    I didn't do a CASE learn. Maybe it needs one?
  14. #194 Re: Won't start after cam install
    Could it be the timing tables?
  15. #195 Re: Won't start after cam install
    id do a case learn
  16. #196 Re: Won't start after cam install
    Anyone have a bin file with a VS cam? I'm just curious.
  17. #197 Re: Won't start after cam install
    My O2 sensor is reading 450. That's it. And I just got a P0134. Gotta be the O2 sensor.
  18. #198 Re: Won't start after cam install
    Hagerstown,Md
    its shot. Or the wires damaged
    "quote"
    A GM O2 sensor signal stuck at 450 mV is an indication of an open O2 sensor circuit (signal wire) or faulty O2 signal ground. The 450 mV value (GM) is called a bias voltage and it is not the same for all manufacturers. Some manufacturers employ a dedicated O2 sensor ground. Such a ground lead is attached to the engine block or chassis and feeds an ECM O2 ground pin only. The O2 circuit is then grounded through the inside of the ECM electronic board by this ground wire. A loss of this ground would also put the O2 sensor signal at around 450 mV, which also makes it look like an open circuit. The same holds true for Chrysler, but these use a different O2 bias voltage, which is usually 2.00 to 4.00 volts
  19. #199 Re: Won't start after cam install
    Quote Originally Posted by 01gpgt01 View Post
    Woops. Forgot to connect the extension harness to the connector.
  20. #200 Re: Won't start after cam install
    Added some fuel. AFR is about 14.8-15.4 at idle now. It feels very rough though. The engine is moving quite a bit, and it sounds like a constant loud tapping noise. I think it's coming from the valve cover. **** it better not be rod knock. I am so ****ing fed up with this ****. This cam install was a ****ing nightmare. Nothing went right.
    I just took it for a drive... I'm saw up to 11 degrees of knock, at extremely low RPMS!!! I don't think I went above 25 mph. !!!
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
