Thread: Won't start after cam install
Page 11 of 23 FirstFirst ... 91011121321 ... LastLast
Results 201 to 220 of 448
  1. #201 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    To summarize, here is a list of my problems:
    - Engine runs very rough and shakes
    - Loud tapping noise (sounds like valve cover, but I don't know)
    - Huge amounts of knock retard at low speeds
    - Bogs down/surges at higher RPM's, leaving me with no power (especially after 3000 RPM)
    - Feels like it hits the rev limiter at 4000 RPM
    - Takes an extra second to start up, kind of stumbles a bit
    - No DTC's
  2. #202 Re: Won't start after cam install
    Find knocking noise first.
  3. #203 Re: Won't start after cam install
    the knocking sound youre hearing is causing your high KR readings. knock sensors 'hear' things so any knocking sound the motor is making will be reproduced as KR. like matt said, find what's knocking.
  4. #204 Re: Won't start after cam install
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    maybe a loose rocker? Garden hose to your ear could help find the knock.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #205 Re: Won't start after cam install
    ^^Dowl rods work really great as well since they are skinny.
  6. #206 Re: Won't start after cam install
    Grand Rapids, MI
    i just bought a $15 stethascope specifically for autos. works great for pinpointing noises. got mine at sears
    maybe you can use that to find your source of noise.
  7. #207 Re: Won't start after cam install
    LOL...just sayin...
    I could make a damn tower for $15.
    Buy.com - Wooden Dowel Rods 12"" 12/Pkg-
  8. #208 Re: Won't start after cam install
    swift current,sask.
    A long screwdriver works just as well, and i'm sure you have one or could find one.
  9. #209 Re: Won't start after cam install
    What's the most probable cause of a frequent tapping noise? Lifters? Would tapping lifters cause a huge problem like the one I'm having? I'm having a lot of trouble figuring it out.
  10. #210 Re: Won't start after cam install
    Grand Rapids, MI
    make a vid of the noise, from under the hood this time. move the camera around different places maybe someone can pinpoint the noise type.
  11. #211 Re: Won't start after cam install
  12. #212 Re: Won't start after cam install
    I looked underneath by my harmonic balancer, and the belt seems to have quite a bit of movement underneath the pulley, going towards the AC compressor. It flaps quite a bit down there. Not sure how much movement is acceptable.
  13. #213 Re: Won't start after cam install
    Hagerstown,Md
    with how fast its knocking its valvetrain forsure. My guess would be rockers
  14. #214 Re: Won't start after cam install
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    yea its the rockers. they aren't torqued to specs. same thing happened to a friend who did a s1x cam and his car misfired and ticked.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  15. #215 Re: Won't start after cam install
    I'd say rockers. I did the same thing when i changed my wifes lim in her grand am
  16. #216 Re: Won't start after cam install
    I just checked the front valve cover. All the rockers are torqued properly. Started it up, and they sound and look fine. I started it up with the cover off and it seems like the sound is coming from the belt area. My tensioner pulley is bouncing around like crazy. I'm not sure if it's something internal causing that or not.
  17. #217 Re: Won't start after cam install
    have you removed the belt yet to see if the ticking goes away?
    a bad a/c clutch can and will snap a belt if its going, and makes a good deal of noise. happened on my truck when the compressor went bad, a/c still worked but the belts kept on breaking till i got a new compressor.
  18. #218 Re: Won't start after cam install
    Removed belt and ran it. Same noise. I'm so ****ing fed up. I ****ing hate this car right now.
  19. #219 Re: Won't start after cam install
    If the balance shaft was out of sprocket alignment, could it cause this? My shakes so bad. I swore I lined it up though.
  20. #220 Re: Won't start after cam install
    HUDSON
    I watched your videos, and I have never seen a supercharger belt also go around the alt., usually the supercharger belt is stand alone, maybe it has somthing to do with the pulley?
    Anyway, from watching your vidoes I can say it sounds like its running on 5 cylinders, and judging by the "kickback" when cranking the engine, there is a good possibility the firing order is not correct, point being, there is an ignition anomoly, timing, fireing order, bad plug, burt/broken wire... or somthing.
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
