Thread: Won't start after cam install
Page 12 of 23 FirstFirst ... 2101112131422 ... LastLast
Results 221 to 240 of 448
  1. #221 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by QUICKSILVER462 View Post
    I watched your videos, and I have never seen a supercharger belt also go around the alt., usually the supercharger belt is stand alone, maybe it has somthing to do with the pulley?
    Anyway, from watching your vidoes I can say it sounds like its running on 5 cylinders, and judging by the "kickback" when cranking the engine, there is a good possibility the firing order is not correct, point being, there is an ignition anomoly, timing, fireing order, bad plug, burt/broken wire... or somthing.
    I run the SS M90 kit. That's why the belt is like that. Which video did you watch? I fixed the no start/cranking problem.
  2. #222 Re: Won't start after cam install
    GT Level Member jdmgtp's Avatar
    MI
    have you check codes for a cylinder misfire? Could be a plug, wire, injector. I'm interested to see what it sounds like when you rev the engine a little.
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  3. #223 Re: Won't start after cam install
    Quote Originally Posted by jdmgtp View Post
    Scanned for DTC's. There isn't one. It sounds good when you rev it at idle, but when driving it, it's sluggish, knocks and ticks. I think I disabled P0300 a while back though. I will re-enable it and see if it throws a multiple misfire code.
  4. #224 Re: Won't start after cam install
    I might just bring it to my mechanic. I'm tired of this ****.
  5. #225 Re: Won't start after cam install
    HUDSON
    I watched your vids of the engine, and in one of the videos I noticed this:
    164d655b.mp4 video by Bedwards923 - Photobucket
    At 45 sec., it looks as though there is a bolt missing.
  6. #226 Re: Won't start after cam install
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    almost sounds like the rotors hitting. Pull off the blower belt and make sure it spins free
    edit: well now that I listen again maybe not lol.
    your WOT run video theres a nasty misfire. ALso sounds like a dead mis on the other video
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  7. #227 Re: Won't start after cam install
    Quote Originally Posted by 01gpgt01 View Post
    I ran it with no belt. Same noise.
  8. #228 Re: Won't start after cam install
    MI
    does the sound get louder with rpm? how about engine load?
  9. #229 Re: Won't start after cam install
    I could hear it while I test drove it. Not sure if RPM affects it or not. I'm honestly just going to to get my mechanic to look at it. I don't have time for working on this anymore.
  10. #230 Re: Won't start after cam install
    MI
    you need to look into that. Don't forget about load...
  11. #231 Re: Won't start after cam install
    I wonder if I have bent valves or something... Since my compression on the cylinders 1 and 3 were so low. It runs like complete ****, misfires and everything.
  12. #232 Re: Won't start after cam install
    Have you checked the compression since it's been running?
  13. #233 Re: Won't start after cam install
    Not yet.
  14. #234 Re: Won't start after cam install
    On my way to test the compression.
  15. #235 Re: Won't start after cam install
    Didn't have time to do a compression test. For anybody who uses HP Tuners, I did a cylinder balance test. I'm very confused by the results. Normally the RPM of all the cylinders are around 90%, give or take 5%.
    I think this issue may be a bent or a set of bent valves. Can someone help me interpret this scan?
    #1 - RPM = 720 - 91%
    TPS = 0.1 - 65%
    #2 - RPM = 927 - 117%
    TPS = 0.0 - 49%
    #3 - RPM = 764 - 96%
    TPS = 0.1 - 65%
    #4 - RPM = 943 - 119%
    TPS = 0.0 - 16%
    #5 - RPM = 748 - 94%
    TPS = 0.0 - 33%
    #6 - RPM = 843 - 106%
    TPS = 0.1 - 50%
  16. #236 Re: Won't start after cam install
    When the harmonic balancer was put on wrong (basically 180 degrees off), everyone was saying that it would throw off the timing. So then is it possible for a piston to hit a valve? I'm confused, because my cam and crank sprocket were still timed properly, connected by the timing chain. I don't see how it would throw off the timing.
  17. #237 Re: Won't start after cam install
    the timing we were referencing is part of the ignition system, so when the spark plugs light up. the timing on the timing chain is different and that is static. if the timing on the timing chain was right then the pistons do not have a chance to hit the valves.
  18. #238 Re: Won't start after cam install
    That sounds like either a rocker/lifter noise or an exhaust leak. Your vids kinda make it sounds like an exhaust leak near the EGR area. And yet, I'd be pulling the valve covers and looking at any w/o oil on them. Any dry ones may have a collapsed lifter or something odd wrong there.
  19. #239 Re: Won't start after cam install
    Should I try an oil additive (Sea Foam or something)?
  20. #240 Re: Won't start after cam install
    Here's what I'd do.
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
