Thread: Won't start after cam install
Page 20 of 23 FirstFirst ... 101819202122 ... LastLast
Results 381 to 400 of 448
  1. #381 Re: Won't start after cam install
    Charles City, IA
    If you where in the states I would mail ya a couple, I found them in my coat pocket from my first build lol.
    SMGPFC Two Nipple General
  2. #382 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by TheOtherNick View Post
    Lol. Awe crap. Thanks though man.
  3. #383 Re: Won't start after cam install
    Found the stupid thing! Haha. I will have this done this afternoon!
  4. #384 Re: Won't start after cam install
    Got it all back together. But my battery needs charging. It's dead as a door nail. I'll let that charge for a while.
    One question. Does anyone know what the clearance should be between the valve spring retainer and the valve seal on LS springs? I'm maybe sitting around 0.030" right now.
  5. #385 Re: Won't start after cam install
    GT Level Member Tea Time's Avatar
    New Brunswick
    God dammit man....take the battery out of ur parent's car! ....lol
    we're all waiting on this
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  6. #386 Re: Won't start after cam install
    Quote Originally Posted by Tea Time View Post
    Hahahahaha.
  7. #387 Re: Won't start after cam install
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Way to add suspense to the thread! lol
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  8. #388 Re: Won't start after cam install
    Charles City, IA
    Quote Originally Posted by Bedwards View Post
    should be more than that. your cam is in the .400s for lift.
  9. #389 Re: Won't start after cam install
    Isn't the lift with the VS cam 0.507 and 0.512?
  10. #390 Re: Won't start after cam install
    Charles City, IA
    might be but think about it if you have .03 till the retainer hits the seal and your rocker moves .5.
  11. #391 Re: Won't start after cam install
    A guy from PRJ says anything over 0.010" is fine. Hmmm.
  12. #392 Re: Won't start after cam install
    Charles City, IA
    hmm i must be off on my thinking tonight.
  13. #393 Re: Won't start after cam install
    Charles City, IA
    You talking valve open or closed?
  14. #394 Re: Won't start after cam install
    Open.
  15. #395 Re: Won't start after cam install
    Charles City, IA
    Ok yeah thats fine then, I thought you where talkin valve closed. Go start that Biznitch
  16. #396 Re: Won't start after cam install
    WOOOOOOOO!!!!!!!!!
    97e4fe58.mp4 video by Bedwards923 - Photobucket
    Thank you everyone!!! So much!!!!
  17. #397 Re: Won't start after cam install
    Every few seconds, I kind of get a deep popping noise, sounds like exhaust. The idle rpm is moving from around 750 to 850, AFR from 14.9 to 16.9, and the boost gauge jumps around 4 psi. Maybe a vacuum leak?
  18. #398 Re: Won't start after cam install
    awesome!, congrats.
    now go enjoy it.
  19. #399 Re: Won't start after cam install
    try the carb cleaner spray test around the engine yet to see if it has a vac leak.
  20. #400 Re: Won't start after cam install
    I think I figured out the vacuum leak problem. I took it for a drive, and at like 30 km/hr, I heard a metallic clank sound, and it jerked. I think it's my CV joint though. When I pulled the motor, the transmission came up a bit too, and stressed it really bad. It's leaking green grease, so hopefully that's my issue here now.
    Could an axle be bad enough that it momentarily clunks and slows the car down?
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
