Thread: Won't start after cam install
Results 1 to 20 of 448
  1. #1 Re: Won't start after cam install
    Quote Originally Posted by Bedwards View Post
    I went to go pull the crank pulley off with the puller, and the f*cking thing doesn't want to budge. I stripped the main bolt on the puller. What the hell is going on? My god.
    sounds like you destroyed the keyway. the pulley should come right off if it's been off recently with the right puller. the only reason it would be stuck is if you smashed the key in there and it is stuck.
  2. #2 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    So how so I get it off??
  3. #3 Re: Won't start after cam install
    i guess get a new puller and grease the treads real good. sounds like you found something here.
  4. #4 Re: Won't start after cam install
    Should I use a hammer too? Try loosen it?
  5. #5 Re: Won't start after cam install
    i wouldn't do that myself, try a new puller.
  6. #6 Re: Won't start after cam install
    I stripped 2 pullers. It's not moving.
  7. #7 Re: Won't start after cam install
    GT Level Member Tea Time's Avatar
    New Brunswick
    oh snap....DO NOT DO THIS UNTIL A COUPLE OF THE SENIOR GUYS ON HERE THINKS ITS OK TO but could he use a rubber hammer to tap it or even a hammer and a piece of hardwood as to not damage the pulley?
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
