Thread: Won't start after cam install
Results 1 to 20 of 448
  1. #1 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Brandon..
    Please try what we chatted about.
    ICM harness to ensure it's getting the right signals from the sensors.
    Clean and dry plugs. I'd like to see you have the plugs out overnight and or while you do the harness. That way they aren't fuel fouled and not throwing a spark.
    Unplug the maf and try to start the car wtih a little throttle.
    Pull the balancer to ensure that it is on properly and somehow isn't misaligned off the keyway and it didn't destroy the key.
    Check for bad/bent pins on the crank sensor.
    If you are postive your firing order is correct and when you said first coil you meant the top one, then it shouldn't be anything other than one of the above. If you have spark and fuel, which you say you do...it's something timing wise and likely the harness or a sensor.
    Yep. I'm gonna do all this tonight.
  2. #2 Re: Won't start after cam install
    Quote Originally Posted by Bedwards View Post
    I thought you were all over everything last night.
  3. #3 Re: Won't start after cam install
    All the junkyards were closed. I couldn't pick up a new harness. I'll grab one after school today. I checked my crankshaft position sensor connector and all the pins look good.
  4. #4 Re: Won't start after cam install
    That's not what I was hoping to hear. (the sensor would have been an easy fix)
  5. #5 Re: Won't start after cam install
    Which sensor? The camshaft position sensor? I took everything apart. So I'll just do it all tonight.
  6. #6 Re: Won't start after cam install
    Nah..pins on the crank sensor. If one was bent or something that would have been nice.
  7. #7 Re: Won't start after cam install
    Oh I see what you mean. Ya I know. I wish it was something simple like that.
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
