Thread: Won't start after cam install
Page 4 of 19 FirstFirst ... 2345614 ... LastLast
Results 61 to 80 of 448
  1. #1 Re: Won't start after cam install
    Delaware, OH
    I could be wrong in my thinking so someone correct me if I'm wrong.
    Higher load springs could make it tougher.
    The cam profile as well, since it's changing when valves open so more pressure may be building?
    Almost sounds like the battery itself could be dieing. Ok voltage but low amperage. I hate trying to diagnose over the internet. Sucks ur all the way in canada. I'd drive an hour or two, but thats too far lol.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  2. #2 Re: Won't start after cam install
    Minnesota
    Im a little drunk right now but is the supercharger and alt on the same belt? could that have anything to do with it lol
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  3. #3 Re: Won't start after cam install
    Quote Originally Posted by Ricky21 View Post
    Quit lying...we know you don't know what an SSM90 kit is
  4. #4 Re: Won't start after cam install
    you can whack at it all you want to get it to move, but a puller should have done the job.
  5. #5 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Did a compression test. Mind you, the motor was cold (obviously):
    Cylinder 1 - 90
    Cylinder 2 - 120
    Cylinder 3 - 80
    Cylinder 4 - 110
    Cylinder 5 - 115
    Cylinder 6 - 120
  6. #6 Re: Won't start after cam install
    The puller is failing miserably. Won't even move it.
  7. #7 Re: Won't start after cam install
    Got the Snap On puller. This thing is heavy duty. I work tonight, so I won't be able to get a start on trying to get the thing off until tomorrow morning.
  8. #8 Re: Won't start after cam install
    Nov 2010
    Atlanta Ga
    Please do not use a hammer! Your crank thrust bearings will take all the abuse.
  9. #9 Re: Won't start after cam install
    The Snap On puller got it off no problem. I'm gonna pull the front cover and check the timing.
  10. #10 Re: Won't start after cam install
    Ummm...front banks a little low....?
  11. #11 Re: Won't start after cam install
    Everything looks a little low. I'm thinking you didn't block the throttle or something. Not sure if I believe the compression test.
    As for the balancer. That's where I'd concentrate now. Something is very wrong if the bolt is out of it and it's not coming off.
  12. #12 Re: Won't start after cam install
    Is there anyway I could have overtightened the pulley and messed up the alignment of the crank?
  13. #13 Re: Won't start after cam install
    Remember how I said the other night that I get the keyway to engage by pushing and turning until it seats. What I left out is once it seats... I hit the bolt with my airgun. It's a 1/2" Ingersold Rand gun with 500 forward ft lbs of torque. Reverse is 600.
    When that bolt stops moving..it's at spec.
  14. #14 Re: Won't start after cam install
    Something is preventing it from turning. Something is binding. Could the pulley make tht kind of an issue?
  15. #15 Re: Won't start after cam install
    Delaware, OH
    You'll need a torch if you're wanting heat. Heat gun won't phase it.
    No More GTP for me.
  16. #16 Re: Won't start after cam install
    heat the balancer with the torch, not the crank, and when you have tension on the puller like it feels like it wont move, tap the balancer,, work the puller tap the balancer and so on, hopefully that will let it pop forward, little by little.
  17. #17 Re: Won't start after cam install
    Heat the front of the pulley? Like around the shaft? Or the side of the pulley (where the belt runs)?
  18. #18 Re: Won't start after cam install
    heat the front of the balancer around the crank, but try not to heat the crank, you want the balancer to expand.
  19. #19 Re: Won't start after cam install
    Denver
    Doesn't the harmonigc balancer have a rubber insert in it (for damping purposes)? If so, get ready to replace your balancer it you put a rosebud to it....
  20. #20 Re: Won't start after cam install
    Delaware, OH
    Honestly you may as well replace the crank sensor while you have everything apart again.
    No More GTP for me.
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
