Thread: Serious part throttle kr and stalling.
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 41 to 60 of 140
  1. #41 Re: Serious part throttle kr and stalling.
    Kemmerer, Wyoming
    if you had an HP Tuner, you could disable your ac compressor and then see what happened, I'm not sure if DHP can do that.
  2. #42 Re: Serious part throttle kr and stalling.
    May 2017
    Dirtyzville, Mizzery
    Quote Originally Posted by suitercrew View Post
    Do you know if O'Reilly or autozone does that? I know they test the batterys but Idk about alternstors?
    Sent from my LG-H918 using Tapatalk
    They do. It's also free. They have a test machine that it plugs/bolts up to and they put it under typical load conditions.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  3. #43 Re: Serious part throttle kr and stalling.
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Quote Originally Posted by SgtMarshal View Post
    Dhp can do that but I don't know what the point would be.
  4. #44 Re: Serious part throttle kr and stalling.
    Oct 2015
    Well thanks guys. Looks like I'm taking a trip to oreillys and taking the car apart in their parking lot ☺
  5. #45 Re: Serious part throttle kr and stalling.
    Kemmerer, Wyoming
    to see if it is putting a load on the electrical system
  6. #46 Re: Serious part throttle kr and stalling.
    Oct 2015
    Well I replaced my fpr today since I had a spare and I was getting a fuel smell from the vacuum hose connected to it, no change like I expected. The slow response for my front o2 sensor code came up again I'm just not sure I should go spend 60$ on something when theres a good chance its something else. Plus ministering o2 data it looks farely normal and does shoot up to the 900s when I go heavy throttle
  7. #47 Re: Serious part throttle kr and stalling.
    Oct 2015
    Swapped plug wires from cylinder 2 & 4 with no change keep in mind I'm seeing misfires in all cylinders at least on startup cylinder 2 is just the most prominent one. Also changed fuel filter and that didn't change anything. When I was relieving the fuel pressure to do the filter though towards then end it was still pressurized but only air was coming out of it? Does this mean my fuel pump is sucking air and maybe that's my problem?
  8. #48 Re: Serious part throttle kr and stalling.
    Oct 2015
    Does anyone have knowledge of where the orings are in the fuel system. The problem has finally gotten bad enough that I can tell its going lean with the wideband and more importantly the car is running worse after changing the fuel filter which wouldn't make any sense except I noticed the oring on the filter was not looking to good but figured I'd re use it and check for leaks. There are no visual leaks but before I replaced the filter the system was atleast somewhat holding pressure and now its not holding pressure.
  9. #49 Re: Serious part throttle kr and stalling.
    Oct 2015
    So my a/c compressor keeps kicking on and off constantly?
  10. #50 Re: Serious part throttle kr and stalling.
    May 2008
    Schuyler, NE
    If it's not leaking, your orings are fine. Did you check fuel pressure yet?
  11. #51 Re: Serious part throttle kr and stalling.
    Oct 2015
    I went ahead and replaced it just because I found one that would work in my collection. I hope to get a fuel pressure gauge hooked up to it tomorrow. I'm gonna pull the pump out tonight just to inspect it though
  12. #52 Re: Serious part throttle kr and stalling.
    Oct 2015
    Could leaky valve cover gaskets cause issues like this?
  13. #53 Re: Serious part throttle kr and stalling.
    Jun 2017
    Alberta
    The first thing that comes to mind is maybe your o2 sensor/ commanded fuel is getting messed up. I had a problem when using my plx wideband gauge to send the signal back to the pcm. But because the wire was relatively un shielded and running next to my amp power. It woukd go out of whack every now and then. It would work fine and then go whacky. Once it went whacky my car would over fuel, lean out sometimes and stall. Dont know if you are using your wideband to send the signal back to the pcm... but just and idea
    Sent from my SM-G920W8 using Tapatalk
  14. #54 Re: Serious part throttle kr and stalling.
    Jun 2017
    Alberta
    But in general it sounds like a fueling problem. Injectors all good as well?
  15. #55 Re: Serious part throttle kr and stalling.
    Oct 2015
    Quote Originally Posted by w3tbanana View Post
    Ya I don't have my wide band connected to the pcm. I did get an o2 slow response code but am nervous about spending 60$ on something that I really don't think will fix the problem. The o2 data is only used in closed loop which is basically normal cruising around town or at idle after your warmed up. My problem is at idle before and after warmed up but I have zero problems and zero misfires cruising around and then at wot when the o2 sensor data is once again not being used I have issues. So Idk man I'm going insane. I think its fueling but if it was fueling why would it happen at idle with such a low load on the engine but then be fine cruising around town at basically anything under 40% throttle. It just doesn't make sense. Hppefully my dad can come over tomorow with his fuel pressure tester and compression tester. I'm just really hopeful its not a chipped piston or something but when I pulled the spark plugs they all looked perfect. No build up or deposits on them. Basically brand new with a hint of burn on them. Ive had the car over 2 years and never replaced the crankshaft or camshaft position sensor I know normally the car just won't start if one is bad but I'm wondering if I have one that is just half dead or something.
  16. #56 Re: Serious part throttle kr and stalling.
    Jun 2017
    Alberta
    Try just unplugging the sensor. If it still runs fine at idle, you can rule that out. I drove my Buick with no 02 sensor for a month before finally getting things back to normal. I use the stock sensor, and tapped my down pipe for the wide band. Damn is it hard to find taps that big in Kanuckistan
  17. #57 Re: Serious part throttle kr and stalling.
    Oct 2015
    My innovate wideband came with the bung but I guess that's just because I'm cool haha. I'm going to the junkyard tomorrow to pick up whatever random parts I think might help. Like a new map sensor. An alternator. A non venturi fuel canister. Hmm any other ideas I should grab while I'm there that could potentially help me out. Like maybe a new friggin engine lol
  18. #58 Re: Serious part throttle kr and stalling.
    Oct 2015
    So I just went to start my car and it started fine but I noticed the dic, stereo, and cel codes were all reset like the battery had just been pulled or something. But I haven't touched the battery??
  19. #59 Re: Serious part throttle kr and stalling.
    Jun 2017
    Alberta
    Check your battery connections.
  20. #60 Re: Serious part throttle kr and stalling.
    Oct 2015
    Dear geez people ok. So I seemed to have 90% fixed the problem. I added 8% to my fuel trims and upped my timing advance a couple degrees and now the misfire at idle is gone and going wot is sometimes perfect and sometimes has a little hick up but nothing like it was before. The problem is I'm now running a 10.1 afr and I still am having random cylinder misfire according to the aeroforce I just can't really feel it. So why did adding a butt ton of fuel bandaid my problem?
  1. Part throttle KR... How bad is it... really??
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 12-24-2016, 06:42 PM
  2. Serious KR at part throttle only
    By 97AutoXVette in forum PCM Tuning
    Last Post: 05-09-2016, 06:35 AM
  3. High kr at part throttle after going wot
    By DoubleBlown in forum PCM Tuning
    Last Post: 12-19-2012, 06:54 PM
  4. Hesitation at part throttle
    By 99FormulaM6r in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-03-2012, 08:27 PM
  5. part throttle kr
    By Sabrewings in forum PCM Tuning
    Last Post: 06-09-2008, 09:30 PM
