Thread: High kr at part throttle after going wot
Results 1 to 11 of 11
  1. #1 High kr at part throttle after going wot
    Apr 2011
    Tally, FL
    only a high of 5kr when going wot and then random part throttle right afterwards up to 14kr
    www.dropbox.com/s/mviu1f4ir4g1bt7/RACETRACK_12-19-2012_10_28_54_AM_1.zip
  2. #2 Re: High kr at part throttle after going wot
    Your IAT's are way too high unless this is post blower.
    Part throttle knock appears to begin at MAP of 80-90 which is almost WOT for a N/A engine.
    I'd suggest running ~13 AFR around that point, perhaps back the timing off a little as well.
  3. #3 Re: High kr at part throttle after going wot
    May 2008
    Schuyler, NE
    Does it consistantly spike to 14* when you get back into the throttle after a pull? Or was this just a freak thing?
  4. #4 Re: High kr at part throttle after going wot
    Apr 2011
    Tally, FL
    idk this was the first time i went wot but i've seen high kr before when going up steep hills on the highway
  5. #5 Re: High kr at part throttle after going wot
    Quote Originally Posted by DoubleBlown View Post
    Try commanding less timing first. see how far that gets you.
  6. #6 Re: High kr at part throttle after going wot
    It's called TCC lockup.
    Let off the gas and unlock the TC and get back into it.
  7. #7 Re: High kr at part throttle after going wot
    May 2008
    Schuyler, NE
    Are you using HPT or DHP to tune?
  8. #8 Re: High kr at part throttle after going wot
    Feb 2009
    flintnasty MI
    who cares.
    op, the 5kr at wot would imply problems.. and they would translate to more at part throttle. Change your PE entry if you want to throw fuel at your problems, but it sounds like your car hates you.
  9. #9 Re: High kr at part throttle after going wot
    May 2008
    Schuyler, NE
    who cares.
    I do.
  10. #10 Re: High kr at part throttle after going wot
    Apr 2011
    Tally, FL
    using dhp
  11. #11 Re: High kr at part throttle after going wot
    do not mask your kr with fuel. thats stupid and just hiding the real problem.
    re work the timing table.
  1. ZZPerformance High Velocity Throttle Body
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2012, 02:43 PM
  2. Hesitation at part throttle
    By 99FormulaM6r in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-03-2012, 08:27 PM
  3. vid shot of my car going part throttle boost
    By fst in forum Track Sessions and Kills
    Last Post: 09-08-2011, 10:51 AM
  4. Misses and KR at part throttle, oh and low compression on six
    By matt5112 in forum General Tech Discussion
    Last Post: 09-15-2010, 12:43 PM
  5. part throttle kr
    By Sabrewings in forum PCM Tuning
    Last Post: 06-09-2008, 09:30 PM
