Thread: 1st time tuning/upgrading advice
Page 5 of 7 FirstFirst ... 34567 LastLast
Results 81 to 100 of 134
  1. #81 Re: 1st time tuning/upgrading advice
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Flush. Flush it as many times as you can. Garden hose in the rad and run the engine for hours if you have to.
    Dexcool sucks hairy donkey balls.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  2. #82 Re: 1st time tuning/upgrading advice
    how to flush coolant:
    remove the t stat, put the t stat housing back on, take the upper hose off the radiator, then push it down to the ground to a bucket or let it fly.
    get your garden hose out, put it in the rad turn it on, then fire up the car, let it run till clear water pumps out the top hose.
    then turn the hose off, run the car till no more water comes out the upper hose. then turn it off.
    put your t stat back in, with new gasket, the upper hose back on.
    now take 1 gallon of full strength green antifreeze, not the 50/50 crap. ( parts store cheap green is fine to use) dump the whole gallon in the radiator, fire up the car, fill the rad with hose water till its full. top as needed till its ready to be bled of air. it will burp and take coolant as the water in the block warms up the t stat opens up for a few seconds till cold coolant hits it and it shuts again.
    now to bleed the air out, let it idle rad cap off till the fans turn on, (when the fans are on the temp is over 195 deg, the t stat is wide open) then open the bleeder screw on top the t stat housing a few turns till a steady stream of coolant comes out the hole, shut the screw, top off the rad. cap it.
    use what ever coolant you want to. it really dont matter, dex has been fix to not sludge up.
  3. #83 Re: 1st time tuning/upgrading advice
    Kemmerer, Wyoming
    dexcool isn't horrible, but it's not my first choice. I use the universal stuff, can't remember what color it is.
    edit: you wrote dextron, and that is transmission fluid, but spelled wrong.
  4. #84 Re: 1st time tuning/upgrading advice
    Jan 2014
    AR
    Don't forget to dump and clean out the coolant reservoir also!
  5. #85 Re: 1st time tuning/upgrading advice
    Oct 2014
    Frederick, MD
    Pressure washer is really the only way to get that reservoir clean. Lol
  6. #86 Re: 1st time tuning/upgrading advice
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Quote Originally Posted by WarStryker13 View Post
    I have had good luck using Simple Green and a couple palms full of BB's, with tank removed add a little S.G. & BB's & fill to only about 1/4. Then get out all your aggressions & shake the sh!t out of it, turning it around, for a couple minutes. OBVIOUSLY discard BB's and rinse......E.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  7. #87 Re: 1st time tuning/upgrading advice
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
    You should also have the heat on full blast right to flush the heater core?
  8. #88 Re: 1st time tuning/upgrading advice
    nope. no need the core has coolant to it full time. old cars you had a valve that shut the flow to the core. and turning the fan on didnt do jack back then either.
  9. #89 Re: 1st time tuning/upgrading advice
    SE Level Member Garandpa's Avatar
    Oct 2016
    Davisburg, MI
    Headers are in!!!. Followed the how-to instructions from this site. Stripped the hex on one stud, but other than that it all went together just fine. Now just have to put everything else back together and make my mods. Mooo hooo ha ha!
  10. #90 Re: 1st time tuning/upgrading advice
    congrats, enjoy the loss of boost lol but also the loss of kr, so its gonna feel better.
  11. #91 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    I've been looking for threads on hiw to change the PCM this morning to no avail. Is it a military secret or just so easy it needs no explanation?
  12. #92 Re: 1st time tuning/upgrading advice
    It's just a couple of bolts that hold the wire harness in.
  13. #93 Re: 1st time tuning/upgrading advice
    its mounted inside the airfilter box. you need to open the box to get to it, then its a bolt in the middle of each plug, the bolt dont come out of the plug, so pull up on the plug as you unbolt it.
    unhook the battery first.
  14. #94 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Everything is complete, except for the thermostat change (forgot a new gasket). I'm going to flush the cooling system when i do that anyway.
    But the car runs great! Has a bit of a growl that wasn't there before, but it's a sleeper for sure. Acceleration seems improved but it's rainy so the tires spin pretty easily. The drive to work tomorrow will be more fun than usual!
    Thanks everbody for the help. This site made the job much less daunting. Life is good!
  15. #95 Re: 1st time tuning/upgrading advice
    you got the 3.4 pulley on too? if so you will feel that for sure.
  16. #96 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    3.5 but yeah. The belt ZZP sold me doesn't fit, but the stock one does. I'll get a suitable replacement this week.
    I got my scanner going too (thanks Marshall). If only I knew what i was looking for! What should I be watching on torque pro?
  17. #97 Re: 1st time tuning/upgrading advice
    long term fuel trims, timing advance, knock retard, then the less important things like trans temp, coolant temp, volts, o2 volts.
    id drive it some what nice for a day or so to let the fuel trims learn, if you see kr right away it might go away once the pcm learns.
    i used to run the stock belt on a 3.4, so your belt is still ok use.
  18. #98 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    I don't see KR as a parameter on torque pro. Is it called something else?
  19. #99 Re: 1st time tuning/upgrading advice
    knock retard. you need to load gm pid's.
    this guy has the directions listed in plain english really.
    http://www.grandprixforums.net/threads/79239-Bluetooth-and-Torque-Pro-app-Live-KR-monitor
    load up the pids, then see if kr is listed, if not add torque scan its a free add on.
  20. #100 Re: 1st time tuning/upgrading advice
    Kemmerer, Wyoming
    glad you got it working. when you start scanning all that stuff, if you are like me, you will see how little you know about cars. the more you learn, the more you learn how little you really know.
  1. Tuning advice
    By TEK310 in forum PCM Tuning
    Last Post: 12-29-2013, 10:01 AM
  2. Replacement time looking for advice
    By TeacherCreature in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2013, 06:59 AM
  3. need tuning advice
    By asite57 in forum PCM Tuning
    Last Post: 04-22-2012, 10:39 PM
  4. advice on upgrading a stock '98 gt
    By mhoran89 in forum Introductions/Noob Questions
    Last Post: 06-05-2009, 04:56 PM
  5. Tuning Advice?
    By Lawngoose in forum PCM Tuning
    Last Post: 10-15-2008, 09:03 PM
