Thread: 1st time tuning/upgrading advice
Page 7 of 7 FirstFirst ... 567
Results 121 to 134 of 134
  1. #121 Re: 1st time tuning/upgrading advice
    SE Level Member Garandpa's Avatar
    Oct 2016
    Davisburg, MI
    So how am I getting MAF readings on the OBDII? At idle I get around 50cfm and cruising around 300cfm. I didn't do anything to the MAF sensor yet because I didn't realize it had tamper torx screws.
  2. #122 Re: 1st time tuning/upgrading advice
    just cause you see a signal dont mean its a good signal, the code says it suffers from low voltage. that means its not working right.
  3. #123 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    New MAF sensor did the trick. Now I can drive her like the hot rod she is! Highest KR I saw was 1.7 with the hammer down.
  4. #124 Re: 1st time tuning/upgrading advice
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
  5. #125 Re: 1st time tuning/upgrading advice
    that might go away after the trims re learn.
  6. #126 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Sweet. What else should I be keeping an eye on?
  7. #127 Re: 1st time tuning/upgrading advice
    just the long term fuel trims and kr really.
  8. #128 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    So I've got about 700 miles on it since the mods. Driving to work I might see up to 1.0 KR, but when I really got on it on an entrance ramp, I recorded 2.4 KR. How much is too much?
  9. #129 Re: 1st time tuning/upgrading advice
    Kemmerer, Wyoming
    do you have an L67, and what are you mods?
  10. #130 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    L67, headers, 3.5 pully, zzp tune, NGK TR6's, 10.5mm wires, MSD coils,180 degree thermostat.
  11. #131 Re: 1st time tuning/upgrading advice
    Kemmerer, Wyoming
    a 3.5" pulley should be good with those mods, I would look around and see if you can find anything like an O2 sensor hitting on the firewall. I wouldn't think you would have any kr with those mods and pulley. might be worthwhile to look for a spark plug wire that is running too close to the header and is shorting out. I usually don't worry about kr less than 1*.
  12. #132 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    O2 sensor could be hitting tunnel occasionally. I bought an extender but realized i cant install it with the header attached. Maybe if i take off the dogbones and disconnect the catback and rock the engine.
  13. #133 Re: 1st time tuning/upgrading advice
    Kemmerer, Wyoming
    If you can get under the car, you could also use a hammer to dent in the firewall
  14. #134 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Quote Originally Posted by SgtMarshal View Post
    Yeah, I tried that twice. First, when I installed the headers, and then again, when I realized the bung extension fitting didn't fit with the headers installed. That tunnel sheet metal is some strong stuff, especially right where the O2 sensor needs relief! I have a bung I can weld on somewhere, so I may go that route. The O2 sensor only has about a half inch clearance, or maybe a little less where it is right now on the Speed Daddy's.
  1. Tuning advice
    By TEK310 in forum PCM Tuning
    Last Post: 12-29-2013, 10:01 AM
  2. Replacement time looking for advice
    By TeacherCreature in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2013, 06:59 AM
  3. need tuning advice
    By asite57 in forum PCM Tuning
    Last Post: 04-22-2012, 10:39 PM
  4. advice on upgrading a stock '98 gt
    By mhoran89 in forum Introductions/Noob Questions
    Last Post: 06-05-2009, 04:56 PM
  5. Tuning Advice?
    By Lawngoose in forum PCM Tuning
    Last Post: 10-15-2008, 09:03 PM
