Thread: What size pulley Should i order?
Results 1 to 3 of 3
  1. #1 What size pulley Should i order?
    Sep 2015
    Denver
    Hey guys just trying to get an idea what kind of pulley i should look at running. Iv tried looking around but haven't found any solid information with something similar to what i run. Here is the setup i will be running.
    *Headers With a ZZP Catback
    *Ported Lower manifold with a SSIC (GEN 3)
    *K&N intake
    *E85 With either Deka 60# or 80# Injectors (Contemplating a fuel pump upgrade.)
    *Custom Tune Will be done
    *104 Plugs, 180 Thermostat
    *Yella Terra 1.8s with LS6 springs
    Right now im running without rockers and E85 on a 3.2 @ 17* of timing on 91. Im thinking about maybe a 3.0 on the same timing or possibly even a 2.9. Just want some opinions before i go any further or if a 3.0 or a 2.9 is way too small for what im going to be running. Thanks All!
  2. #2 Re: What size pulley Should i order?
    SE Level Member 01Blackgtp's Avatar
    May 2014
    Colorado
    If there is no kr, go to a 2.8. You need a machined snout to go smaller than that.
  3. #3 Re: What size pulley Should i order?
    May 2008
    Schuyler, NE
    Depends on the pulley system. Some can go smaller than a 2.8 without machining.
    You are most likely going to need a pump and rewire to go smaller than a 3.0.
  1. Replies: 9
    Last Post: 07-13-2016, 09:16 PM
  2. Pulley Size?
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2012, 10:48 AM
  3. wbody store full-size intercooler with 42.5's = what size pulley?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 07:18 PM
  4. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  5. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
