Thread: 1st time tuning/upgrading advice
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 41 to 60 of 134
  1. #41 Re: 1st time tuning/upgrading advice
    band clamped in there.
  2. #42 Re: 1st time tuning/upgrading advice
    Omaha, NE
    I wouldn't run a cat unless you have emissions where you live.
  3. #43 Re: 1st time tuning/upgrading advice
    Topeka, KS
    Quote Originally Posted by Garandpa View Post
    Done. Does this bolt on or weld?
    Weld it. I have SSAC headers and I've blow that mid pipe off at Wide Open Throttle twice until I had it welded.
  4. #44 Re: 1st time tuning/upgrading advice
    SE Level Member Garandpa's Avatar
    Oct 2016
    Davisburg, MI
    I bought a ZZP downpipe that has a cat in it. Will that fit in place of the Speed-daddy downpipe?
  5. #45 Re: 1st time tuning/upgrading advice
    Nope.
    Not unless you hack the cat off the downpipe and weld/clamp it in place. Then you couldn't sell the downpipe for profit.
    SD comes with there own downpipe section that fits nothing else but the SD supplied parts.
  6. #46 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Nope.
    O.K. back it goes then. As for the SD header install, the sticky in the how-to forum mentions bashing in the firewall to get the O2 sensor to fit. Is there not a better way? Can I weld in an alternate port somewhere?
  7. #47 Re: 1st time tuning/upgrading advice
    you can weld in a new bung in a clear area. you will need a o2 harness extension too.
  8. #48 Re: 1st time tuning/upgrading advice
    Yeah, you can move the o2 sensor further down or rotate it in close to the same position to clear the firewall better.
    Some even move it to the cross over pipe in the engine bay. You'll want a o2 extension harness for either or make your own. ZZP sells them for like 10-15 bucks I think, I prefer them to making one. No risk of them coming apart from a bad solder and the extension harness's are good qaulity connectors for weather proofing.
  9. #49 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Does the Speed daddy header/downpipe get rid of the u-bend?
  10. #50 Re: 1st time tuning/upgrading advice
    yes, see my pic, right side is the flange to the cat back.
  11. #51 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Pardon my ignorance but will the SD package mount up to my stock exhaust or do i need an aftermarket cat-back kit?
  12. #52 Re: 1st time tuning/upgrading advice
    bolts right up to stock cat back. aftermarket cat back is worthless too.
  13. #53 Re: 1st time tuning/upgrading advice
    Nov 2011
    NY
    Not entirely true (Catback wortless). It all depends on your plan, where you want to take the engine, car. If mild mods, sure, just open up the exhaust a little with headers and provide better flow in/out and you'll see a nice improvement in acceleration. But, if you plan to cam your engine, open up intake, heads, headers, etc., then a 3" exhaust to the tails benefit. I went 3" all the way early on with the knowledge in the future I would mod more. It certainly didn't hurt anything. And for the exhaust notes or sound, some say it'll always sound like crap, but try using the vibrant ultra quite resonator and Hooker MaxFlow mufflers... Is the best sound hands down you'll ever get from this engine. Use youtube, you'll see
  14. #54 Re: 1st time tuning/upgrading advice
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    Quote Originally Posted by WarStryker13 View Post
    ^^^ headers fer sure.
    And a mail order tune is always an eh upgrade, the real upgrade would be a proper tune from either a reputable shop that knows how to tune a 3800, or a local friend with a tuner.
    Mail order tunes, or "canned" tunes never get the full potential that an actual tune will, because every car is different and canned tunes are all the same.
    Amen brother!
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  15. #55 Re: 1st time tuning/upgrading advice
    Apr 2013
    Waldorf MD
    for headers most of us run speed daddy headers, 220 shipped most of the time. add some band clamps and your all set. for 250 in all.
    I run these. Whole different car. Now if I can get up off my butt and retune. The boost weather is upon us!
  16. #56 Re: 1st time tuning/upgrading advice
    Apr 2013
    Waldorf MD
    Quote Originally Posted by Mitch R View Post
    I will say that I was able to raise my mpgs a fair amount when I tuned it myself. I added a bunch of timing to the cruise tables, way more than any of the canned tunes I've seen have.
    Same here! I CAN get almost 30+ IF i can keep from going deep and making her whine... I mean make boost. LOL
  17. #57 Re: 1st time tuning/upgrading advice
    Apr 2013
    Waldorf MD
    I dont. I tuned the O2's out. Just went thru emissions 2 saturdays ago and passed. Im in Maryland.
  18. #58 Re: 1st time tuning/upgrading advice
    Quote Originally Posted by coolone View Post
    i member here "buck" did a 3 inch cat back and lost HP on the dyno. theres no gains for a sc engine on a 3 inch. a turbo sure. not a sc.
  19. #59 Re: 1st time tuning/upgrading advice
    May 2012
    Where winter never ends
    The catback does become an issue at higher power numbers. I was knocking like a ***** on 18 PSI of boost on my turbo setup. Swapped to ZZP catback (which honestly, I thought sounded good but I was turbo so everything I know is a lie) and all the knock was gone. I then turned it up to 26 psi and KABOOM wen't the transmission, but we dont talk about that
    2000 Regal - Winter Beater
  20. #60 Re: 1st time tuning/upgrading advice
    Kemmerer, Wyoming
    if I do anything it will be a 2.5" stainless from mandrel exhaust systems. the link is for 04+, but they have 97-03 as well.
    http://www.mandrelexhaustsystems.com...ND-PRIX/Detail
  1. Tuning advice
    By TEK310 in forum PCM Tuning
    Last Post: 12-29-2013, 10:01 AM
  2. Replacement time looking for advice
    By TeacherCreature in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2013, 06:59 AM
  3. need tuning advice
    By asite57 in forum PCM Tuning
    Last Post: 04-22-2012, 10:39 PM
  4. advice on upgrading a stock '98 gt
    By mhoran89 in forum Introductions/Noob Questions
    Last Post: 06-05-2009, 04:56 PM
  5. Tuning Advice?
    By Lawngoose in forum PCM Tuning
    Last Post: 10-15-2008, 09:03 PM
