long term fuel trims, timing advance, knock retard, then the less important things like trans temp, coolant temp, volts, o2 volts.
id drive it some what nice for a day or so to let the fuel trims learn, if you see kr right away it might go away once the pcm learns.
i used to run the stock belt on a 3.4, so your belt is still ok use.
