Thread: 1st time tuning/upgrading advice
Results 1 to 20 of 134
  1. #1 Re: 1st time tuning/upgrading advice
    SE Level Member Garandpa's Avatar
    Oct 2016
    Davisburg, MI
    Quote Originally Posted by SgtMarshal View Post
    that's a lot of kr. the maf sensor is located directly on top of the throttle body. the part you can see is squareish, but there is a leg that drops down into the airflow portion of the throttle body. if you replace it, do not buy an aftermarket. either find a used one, or you can get an oem one from amazon like this:
    https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
    I'll try to clean it first. Hopefully, it's just gunked up. Apparently, there's a special cleaner for those made by CRC?
    Also, does the high KR indicate actual knock, or is it a bad result of a calculation?
  2. #2 Re: 1st time tuning/upgrading advice
    Kemmerer, Wyoming
    Quote Originally Posted by Garandpa View Post
    CRC does make maf sensor cleaner. I keep a bottle of it on hand because I use the oiled K&N air filter, so after I change the filter and drive for a bit, I hit the maf with the cleaner just to make sure I clean it if I over oiled the filter.
    The way these knock sensors work, is that they sense piezoelectric frequencies caused by too much pressure in the combustion chamber. so, kr isn't actually engine knock, when you hear the knock, the damage is done and you will need a new block.
  1. Tuning advice
    By TEK310 in forum PCM Tuning
    Last Post: 12-29-2013, 10:01 AM
  2. Replacement time looking for advice
    By TeacherCreature in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2013, 06:59 AM
  3. need tuning advice
    By asite57 in forum PCM Tuning
    Last Post: 04-22-2012, 10:39 PM
  4. advice on upgrading a stock '98 gt
    By mhoran89 in forum Introductions/Noob Questions
    Last Post: 06-05-2009, 04:56 PM
  5. Tuning Advice?
    By Lawngoose in forum PCM Tuning
    Last Post: 10-15-2008, 09:03 PM
