Thread: 1st time tuning/upgrading advice
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 101 to 120 of 134
  1. #101 Re: 1st time tuning/upgrading advice
    SE Level Member Garandpa's Avatar
    Oct 2016
    Davisburg, MI
    So true of so many things. Everybody told me most of my life what an amazing rifle shot I was. Eventually I decided to find out and started shooting NRA highpower and found out how little i knew about marksmanship. Still working on that one too.
    Quote Originally Posted by SgtMarshal View Post
    glad you got it working. when you start scanning all that stuff, if you are like me, you will see how little you know about cars. the more you learn, the more you learn how little you really know.
  2. #102 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Dude, that worked perfectly! Thanks again. [1QUOTE=Scottydoggs;1449451] knock retard. you need to load gm pid's.
    this guy has the directions listed in plain english really.
    http://www.grandprixforums.net/threads/79239-Bluetooth-and-Torque-Pro-app-Live-KR-monitor
    load up the pids, then see if kr is listed, if not add torque scan its a free add on.[/QUOTE]
  3. #103 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Got one fault code on the drive to work: P0102. I'm guessing this may be due to either no mods to my air induction (other than a K&N filter) or related to having just cleaned and oiled the filter. Where is the MAF sensor located anyway?
    I saw a KR reading of 8.4 degrees when I accelerated to almost 4k RPM while already doing about 50 MPH. Driving around normally KR is zero. The only other time I saw any KR happened while accelerating from a stop (again to near 4k RPM) and it only got to 1.2 degrees.
  4. #104 Re: 1st time tuning/upgrading advice
    thats a no voltage code for your maf. check fuse # 21, replace if bad, the maf plugs wires for damage or the maf is bad.
  5. #105 Re: 1st time tuning/upgrading advice
    Kemmerer, Wyoming
    that's a lot of kr. the maf sensor is located directly on top of the throttle body. the part you can see is squareish, but there is a leg that drops down into the airflow portion of the throttle body. if you replace it, do not buy an aftermarket. either find a used one, or you can get an oem one from amazon like this:
    https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
  6. #106 Re: 1st time tuning/upgrading advice
    the maf code is hopefully the cause of the kr, and nothing is learned yet for the pcm.
  7. #107 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    I'll try to clean it first. Hopefully, it's just gunked up. Apparently, there's a special cleaner for those made by CRC?
    Also, does the high KR indicate actual knock, or is it a bad result of a calculation?
  8. #108 Re: 1st time tuning/upgrading advice
    its not dirty, its got no voltage, aka its not working at all. check the things i listed. replace it is the last step.
  9. #109 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Got it.
  10. #110 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Replaced fuse, wiring looks fine. Goodbye $82
  11. #111 Re: 1st time tuning/upgrading advice
    dont buy a aftermarket maf they suck.
    your best off getting a used maf from a junk yard or off ebay. the number on the maf top is the part #.
  12. #112 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    I ordered the Hitachi one from Amazon: $99 with 2-day shipping. The dealership wants $394 for the same one.
  13. #113 Re: 1st time tuning/upgrading advice
    those are supposed to be ok. like they also make oem maf's for gm. used is like 40 bucks most of the time. hell im on a used maf for the last 6 years, best 40 bucks i ever spent lol
  14. #114 Re: 1st time tuning/upgrading advice
    Kemmerer, Wyoming
    Quote Originally Posted by Garandpa View Post
    CRC does make maf sensor cleaner. I keep a bottle of it on hand because I use the oiled K&N air filter, so after I change the filter and drive for a bit, I hit the maf with the cleaner just to make sure I clean it if I over oiled the filter.
    The way these knock sensors work, is that they sense piezoelectric frequencies caused by too much pressure in the combustion chamber. so, kr isn't actually engine knock, when you hear the knock, the damage is done and you will need a new block.
  15. #115 Re: 1st time tuning/upgrading advice
    the sensors pick up detonation and pulls timing in order to save the engine. 8 degrees of kr is likely due to not having a working maf. kr chips pistons too. why your goal is ZERO KR when tuned/modded.
    for every degree of kr it pulls 2 degrees of timing, so 8º kr takes away all your timing pretty much thats neg 16 degrees so if your set to 18 wot like most canned tunes, you were actually running on 2 degrees. and it will just fall on its face when that happens.
    if you see kr, let off, save a piston.
  16. #116 Re: 1st time tuning/upgrading advice
    and you need to run 93 octane if you have it where you live, no less then 91. run 87 and your causing the KR with the wrong gas.
  17. #117 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    So i looked into the P0102 fault a little more and it can be caused by a clogged/dirty MAF sensor. The fault is lower voltage than expected to the PCM. I'm getting variable MAF values on my scanner which leads me to believe it's not completely inop unless there's some other source for MAF readings.
  18. #118 Re: 1st time tuning/upgrading advice
    never heard of a cleaning fixing low voltage, its either the fuse marked ign, the wires, or the maf is dead/dying.
  19. #119 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Low Hz actually, but i have a new sensor inbound anyway. I found an excellent test procedure on easyautodiagnostics.com/gm/3.8L/maf-sensor-diagnostic-tests-2
  20. #120 Re: 1st time tuning/upgrading advice
    the hz is how the pcm reads the maf, p0102 is a low voltage code, like its not getting voltage, or its weak.
    those test would be good for testing the plugs wires too.
    check your o2 harness too for the o2 sensor, its on the same fuse as the maf, the wires get burnt up on the headers sometimes, and blow the fuse for ya. the maf code always comes up first when the o2 wires are damaged.
  1. Tuning advice
    By TEK310 in forum PCM Tuning
    Last Post: 12-29-2013, 10:01 AM
  2. Replacement time looking for advice
    By TeacherCreature in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2013, 06:59 AM
  3. need tuning advice
    By asite57 in forum PCM Tuning
    Last Post: 04-22-2012, 10:39 PM
  4. advice on upgrading a stock '98 gt
    By mhoran89 in forum Introductions/Noob Questions
    Last Post: 06-05-2009, 04:56 PM
  5. Tuning Advice?
    By Lawngoose in forum PCM Tuning
    Last Post: 10-15-2008, 09:03 PM
