Thread: What else for installing i/c?
Results 1 to 20 of 20
USonuMabeaCh What else for installing i/c? 03-10-2016, 07:57 PM
REDCRAPGP Re: What else for installing... 03-10-2016, 08:17 PM
Scottydoggs Re: What else for installing... 03-10-2016, 08:22 PM
ericspecullaas Re: What else for installing... 03-10-2016, 08:25 PM
Scottydoggs Re: What else for installing... 03-10-2016, 08:27 PM
USonuMabeaCh Re: What else for installing... 03-11-2016, 10:30 AM
buck531 Re: What else for installing... 03-11-2016, 11:01 AM
Scottydoggs Re: What else for installing... 03-11-2016, 11:03 AM
buck531 Re: What else for installing... 03-11-2016, 12:01 PM
b4black Re: What else for installing... 03-11-2016, 03:01 PM
Scottydoggs Re: What else for installing... 03-11-2016, 03:30 PM
USonuMabeaCh Re: What else for installing... 03-14-2016, 06:17 PM
b4black Re: What else for installing... 03-15-2016, 08:02 AM
SgtMarshal Re: What else for installing... 03-11-2016, 03:07 PM
b4black Re: What else for installing... 03-11-2016, 04:02 PM
Scottydoggs Re: What else for installing... 03-11-2016, 04:49 PM
SubwayGuy Re: What else for installing... 03-11-2016, 05:30 PM
Scottydoggs Re: What else for installing... 03-11-2016, 05:32 PM
SubwayGuy Re: What else for installing... 03-11-2016, 05:34 PM
Scottydoggs Re: What else for installing... 03-14-2016, 06:24 PM
  1. #1 Re: What else for installing i/c?
    SE Level Member USonuMabeaCh's Avatar
    Sep 2015
    gulf breeze, fl
    Quote Originally Posted by b4black View Post
    Get one of these to tap into the fuse block for pump power:
    http://www.amazon.com/Pico-0956PT-Bl.../dp/B001QRSBW0
    http://zzperformance.com/3800/interc...pump-plug.html
    will that suffice?
    02 40th GTP 2dr SSEI IC ZZP system with 3.2" Wizaird CAI Transgo SK SD headers aeroforce w/WB 1.9s over kill tune | 70 Skylark 455 bored to 462 Stg 1 iron heads ported 270 in 205 ex spx intake 870 street avenger 2" headers 3" xpipe flowmaster 40's full msd ign custom cam 540 hp 560 lbft TH400 2800 stall hotchkis susp DTS 12 bolt 3.42 rear
  2. #2 Re: What else for installing i/c?
    SE Level Member b4black's Avatar
    Oswego, IL
    Quote Originally Posted by USonuMabeaCh View Post
    You should get that pigtail with the pump. I just connected the black to ground. Use a ring terminal and screw it to the frame. Use the add-a-fuse to tap into the fuel block. I think you will need a small piece wire and two splices to cover the length needed. Find a fuse that is hot only when the ignition is on. You will need to cut a slot in the fuse block cover for the wire to slip into.
    I used a length of clear tubing going into the IC core. You can see the coolant moving and tell how many air bubbles there are.
    2002 Buick Regal GS - Intercooler, TOG headers w/ full 3" exhaust, 60# injectors, K&N cone, MPS 2.9, GMPP sway bars and STBs, 18"GXP wheels, 12" impala rotors, alternator hotwire, fuel pump hotwire, HPTuner newbie, Flex Fuel And 1982 Buick Regal GN & 1996 Dodge Ram Diesel 4x4 & Richard Petty's 43 JR Hemi Barracuda drag car
  1. Installing Gpo's
    By Youngster in forum Visual/Body Modifications
    Last Post: 01-13-2016, 11:08 PM
  2. Installing HUD
    By Vile in forum Audio, Security & Visual Electronics
    Last Post: 07-08-2012, 05:03 PM
  3. How would i go about installing this?
    By 2000GTGP in forum Audio, Security & Visual Electronics
    Last Post: 01-06-2011, 01:21 AM
  4. installing HUD
    By joshsGT in forum Audio, Security & Visual Electronics
    Last Post: 03-16-2010, 10:47 PM
  5. Need help installing HUD
    By nabil237 in forum General Tech Discussion
    Last Post: 11-21-2009, 09:22 AM
