you need one tube of rtv, fuel rails of some sort, a res tank is nice, but not needed. i used 3/4 hose only.
no idea id a gp has the room to mount like this, but i welded two bolts to the rad support and nutted it on. made two holes and mounted in and outlets for the hose's.
used marine epoxy to seal them up, bone dry since day one.
you also nee to raise the icm and coils, or grind the bracket, drill new holes and move the icm over some to clear the belt.
how to for that mod http://www.grandprixforums.net/threa...-BillBoost-way
i got a frozen boost 101 fmhe, this mounting bar came with it, i got it used, the ends are capped and threaded, you drill a hole on the side of the rad support and bolt it in, the lower two tabs get bolted to the lower rad support.
the you need to mod the hood latch, this how to install a ic thread covers it http://www.grandprixforums.net/threa...BS-Intercooler
you need to cut the bottom off, then i welded it to the support bar.
my 20 dollar modded fuel rail made from a stock rail and 20 bucks worth of tubing and compression fittings.
and all done
getting your fmhe up high keeps the curbs from killing it too.
