you may also need a 90º elbow i did. the upper port on the fmhe is to close tot he frame to get the hose straight enough, so i put a 90 off it and run the hose up the top side.
id get a hand full of clamps, may need 2 more if you add a 90º elbow.
and id get more hose, it goes fast.
my pump is mounted on a diy bracket, its bolted under the horn bracket. thats muffler band clamp around it for a mounting bolt off it.
im sure most shops have 1/2 a brain, but maybe suggest they cut some cardboard to fit over the condenser. you working like a 1/2 inch off it, and your hands are gonna fudge up the fins, i saw this happen to mine on the first test fits of the fmhe, cardboard was laid in there asap.
