Thread: Problems. HELP???
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Problems. HELP???
    Nov 2013
    Carroll Iowa
    Hey man. I don't know this stuff. I'm just starting out. Gotta start somewhere.
  2. #22 Re: Problems. HELP???
    Omaha, NE
    Get an account on AllDataDiy.com its like $15 for 2 or 3 years and is like a digital chilton manual for lack of a better description. Its going to help you with part numbers, estimated labor times, etc.
  3. #23 Re: Problems. HELP???
    Because motor swaps are fun, and you can learn from them.
    Fun...yes. learn from them. ......yes I don't really know where I was going with this lol
  4. #24 Re: Problems. HELP???
    $150 is crazy expensive for heads
  5. #25 Re: Problems. HELP???
    Banned
    Oct 2013
    Moorhead, MN
    Contact Andrew if you're doing a top swap! =)
    If you're going to keep the same engine, replace the timing set, water pump, and all gaskets and switch to the Dorman UIM. Address any codes. Change the oil in your tyranny and engine (synthetic?). Also, flush the dexcool.
    You should be good to go.
  1. VSS problems
    By diehl2 in forum General Tech Discussion
    Last Post: 08-10-2012, 05:49 PM
  2. Dic ABS TCS problems
    By Boosted98Gtp in forum General Tech Discussion
    Last Post: 10-06-2010, 11:01 PM
  3. So many problems. . .
    By SDGTP99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2010, 02:09 PM
  4. I've got problems...
    By Bakerdd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-12-2010, 06:48 PM
  5. Used car problems.... Help
    By ChipSmithers in forum General Tech Discussion
    Last Post: 02-10-2010, 09:58 PM
