Ok, I've got several little problems that I need to fix but idk whats causing them.
The problems that I've got; "low input to knock sensor 2" & "running lean banks 1 & 2" when scanning the car. I've also got an idle/driveability problem. Sometimes the car idles at up to 2500RPM's other times while driving the the RPM's are way above what they should be. 2500-3000 while cruising at 60MPH etc, & when I let off the gas the car keeps its speed or it accelerates on its own.
I'm guessing the car's running lean because of the ZZPoof PCM or clogged fuel injectors? Everything else I have no clue whats wrong. I needs help please![]()
