Thread: Used car problems.... Help
Results 1 to 4 of 4
  1. #1 Used car problems.... Help
    Feb 2010
    Michigan
    I bought a 99 Grand Prix for my first car about two months ago. Now that i have been driving it for awhile i have noticed some things that are not working right or not sounding right. First, the automatic transmission will shift 1st, 2nd, and 3rd gears flawlessly but when it goes to shift into OD it whines until it shutters into gear. Second, when the gas needle gets down to about a quarter of a tank it will float. The needle will move from quarter of a tank to up to a half and back down till eventually it reads a full tank. I have been using the gallons used on the DIC which i don't know how accurate it is. When the climate control kicks the fan on it has a really annoying clicking sound. it will do it at all speeds but will stop when i turn a corner and brake. I am also trying to find a new sunshade for my sunroof because the one that i have is broken. .
    Thanks in advanced.
    Cody Jones
  2. #2 Re: Used car problems.... Help
    GTX Level Member bronzemist02's Avatar
    Canada
    Transmission shutter into gear could be pressure solenoid. Get it to a shop and get it scanned. If it is the solenoid it should throw a transmission code. The gas needle problem has to do with the fuel level sender on the fuel pump assembly in the trunk or a loose or pinched wire. You can just reset your trip computer at each fill-up and fill it at a certain mileage like I do if you don't want to replace the sender.
  3. #3 Re: Used car problems.... Help
    GT Level Member Haulero's Avatar
    Gray Court, South Carolina. USA
    Quote Originally Posted by bronzemist02 View Post
    Yep, my car has the same problem about the gas needle, once it gets to 1/4, it goes back up until it reads full again but I'm not too worried about that, since I can go 300 miles safe with 1/4 of tank, I always put gas around 280/300 miles to be on the safe side
  4. #4 Re: Used car problems.... Help
    Jul 2008
    sumter,south carolina
    4th gear is about to go bye bye... x2 on fuel sending unit.
    02 GTP with mods 05 GP for DD
  1. A/C problems
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 11:04 PM
  2. Problems with my 04 GP
    By 04gpking85 in forum 04+ Specifics
    Last Post: 10-17-2009, 02:15 PM
  3. Got some problems with my '04
    By 04gpking85 in forum General Tech Discussion
    Last Post: 05-24-2009, 02:50 PM
  4. Having Problems...
    By GP3800TC in forum Turbo
    Last Post: 05-21-2009, 09:53 AM
  5. HID Problems
    By That Guy in forum Visual/Body Modifications
    Last Post: 05-19-2009, 10:58 PM
