Hey man. I don't know this stuff. I'm just starting out. Gotta start somewhere.
Get an account on AllDataDiy.com its like $15 for 2 or 3 years and is like a digital chilton manual for lack of a better description. Its going to help you with part numbers, estimated labor times, etc.
$150 is crazy expensive for heads
Contact Andrew if you're doing a top swap! =)
If you're going to keep the same engine, replace the timing set, water pump, and all gaskets and switch to the Dorman UIM. Address any codes. Change the oil in your tyranny and engine (synthetic?). Also, flush the dexcool.
You should be good to go.
