Thread: maaaaaaasive fuel leak
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
  1. #1 maaaaaaasive fuel leak
    Banned
    Oct 2013
    Moorhead, MN
    Well, the car runs again finally.
    But... The top of injector 4 (back mid) leaks HORRIBLY. It just gushes, sprays everywhere.
    I took the injector out, fiddled with it, replaced both o-rings (again) and put everything back together. Making sure everything was tight and fully seated.
    I think it got worse. I've taken it off again...
    What do?
  2. #2 Re: maaaaaaasive fuel leak
    Dec 2012
    Where 4T65E's were born
    Everything looks good on inspection? No cracks, warps, or anything like that?
    Sold.
  3. #3 Re: maaaaaaasive fuel leak
    from where is it leaking? top o ring, bottom, or did it split?
  4. #4 Re: maaaaaaasive fuel leak
    Banned
    Oct 2013
    Moorhead, MN
    Took it apart, again. Replaced orings, again. Swapped 2 of the injectors. Still leaking badly.
    Fuel is pushing upward from the injector.
    Could the pigtail be bad, and it's not communicating with the injector?
    It's got to be one of 2 things.
    The fuel rail got bent somehow.
    Or injector pigtail 4 isn't communicating. Leaving the injector closed. I did just notice the insulator is missing inside of it.
    But if that were the case, wouldn't fuel just flow past it?
    It wasn't leaking as bad this 4th time. =/
    Looks like that bluetooth obd in reader wasn't such a bad investment this summer.
    Just gotta figure out how to use it.
  5. #5 Re: maaaaaaasive fuel leak
    Banned
    Oct 2013
    Moorhead, MN
    The top of injector 4,at the fuel rail.
    "injector seal", what's that?
    Apparently you can just plug a parking light bulb into your injector socket to test it. LMAO.
    Odd.
  6. #6 Re: maaaaaaasive fuel leak
    Feb 2013
    37.295091, -121.930053
    grab one from a junk yard and see if that fixes it. also grab the fuel rail as well dont need ot make 2 trips out of it.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  7. #7 Re: maaaaaaasive fuel leak
    Banned
    Oct 2013
    Moorhead, MN
    I have $18 in my account.
    This car has ruined me.
  8. #8 Re: maaaaaaasive fuel leak
    if swapping the injector and new o rings dont stop it from leaking id think the fuel rail got bent some how, or some thing is keeping it from seating in the rail.
    clogged injector wont leak fuel it just wont spray fuel out the nozzle.
  9. #9 Re: maaaaaaasive fuel leak
    Feb 2013
    scotty your almost at 14,000 posts man
  10. #10 Re: maaaaaaasive fuel leak
    im creeping up there, bam theres one more lol
  11. #11 Re: maaaaaaasive fuel leak
    Banned
    Oct 2013
    Moorhead, MN
    Could I bring it to a machine shop or something to get it looked at?
  12. #12 Re: maaaaaaasive fuel leak
    take the fuel rail to a machine shop? why? if its damaged replace it.
  13. #13 Re: maaaaaaasive fuel leak
    Feb 2013
    thays why i said this
  14. #14 Re: maaaaaaasive fuel leak
    Banned
    Oct 2013
    Moorhead, MN
    Do they accept payment in tears? Im outta money!!!!!
  15. #15 Re: maaaaaaasive fuel leak
    take yours off, bring it to the junk yard walk in with it, show the guy hey im bring this in to match it up. then swap it, take the jy one out with you, leave yours there.
    some places will let this fly, some wont.
  16. #16 Re: maaaaaaasive fuel leak
    Dec 2012
    How will they not? Just say you couldn't find a better one.
    Sold.
  17. #17 Re: maaaaaaasive fuel leak
    Banned
    Oct 2013
    Moorhead, MN
    Or cram it down my pants.
  18. #18 Re: maaaaaaasive fuel leak
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    Quote Originally Posted by Thompsju View Post
    depends on what type of drivers the pcm uses for injector control. putting a low resistance bulb into a saturated type injector circuit that expects 13ohms can fry the driver.
  19. #19 Re: maaaaaaasive fuel leak
    St. Louis
    I know this may be a dumb question, but have you checked to see if there is an old o-ring or something stuck in the rail on #4?
  20. #20 Re: maaaaaaasive fuel leak
    Banned
    Oct 2013
    Moorhead, MN
    I finally gave in and took the fuel rail off.
    Good news and bad news.
    Good news: the fuel rail is the problem
    Bad news: the fuel rail is the problem
    The #4 fuel rail injector inlet is indeed bent, more like crimped. Not too bad, but obviously bad enough. So instead of messing with it any more, I'm just going to replace it.
    My dad has been friends with a guy in my home town that, in fact, owns a junk yard. So I called him this morning.
    $25 for a fuel rail (with the injectors). Win.
    I might end up making money on this hiccup after all.
  1. Fuel leak??!!!
    By saranykm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2013, 11:42 AM
  2. Fuel line leak at fuel rail
    By Burbman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2013, 12:43 PM
  3. Fuel leak
    By Rona in forum Introductions/Noob Questions
    Last Post: 03-11-2013, 07:21 PM
  4. Fuel leak...
    By akito in forum General Grand Prix Discussion
    Last Post: 07-21-2012, 06:45 PM
  5. fuel leak
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2008, 03:40 PM
