Its been a busy Bronco fixin week but I did find this.... eventually!
If the chunk is still there on at least one hole, superglue that back. If you have a good enough stapler, hit it with that after glue (and hide the staple under the clip). Epoxy-ing a new piece of plastic under it can work for awhile but it will raise the bumper there. I'd just glue the chunk back and keep an eye on it. If it does come loose when driving and if that is irritating when you pop the hood, by all means secure it with a screw or zip-tie. Its your car, just be neat about it. The epoxies out there require great prep work and often don't last as intended if not featheredged and painted over, plus they also add thickness. If you can shove that part back and it stays, I might just leave it alone or roll with just superglue (the gel if possible).
