Thread: Broken rocker arm bolt
Results 1 to 20 of 24
  1. #1 Broken rocker arm bolt
    SE Level Member Wsmccoy's Avatar
    May 2012
    Fort Campbell, ky
    So as the title says I have a broke rocker arm bolt. I put on 105 lb valve springs a week ago and while driving home from work I heard a ticking noise, I know I should of pulled over and inspected it or got it towed home, but when I was a couple blocks from home it got louder and the check engine light came on. I scanned as I was pulling in the driveway and had a misfire code for cylinder 3. Took the valve cover off and found the bolt broke.
    I know it's hard to tell with the pedestal still on but I can tell it's flush with the head. So what are the chances that an extractor could get it out? And just to add I replaced the bolts and torqued everything down just as I did when I installed the 1.9 modified rockers months ago. Is there a possible chance it was a weak bolt? All other bolts are still torqued correctly and not loose.
  2. #2 Re: Broken rocker arm bolt
    The Boss Iceman6669's Avatar
    Jun 2011
    I went through the same issues ... We tried extractor, we even tried welding a nut to the broken stud to back it out... Ended up having to drill it out.
    2011 F-150 Yote powered
  3. #3 Re: Broken rocker arm bolt
    Grand Rapids, MI
    many many carbide drill bits lost their life that day
  4. #4 Re: Broken rocker arm bolt
    Jan 2012
    Philadelphia
    Quote Originally Posted by brandonl2000 View Post
    Maybe a cobalt drill bit, a carbide bit should hold up pretty well
  5. #5 Re: Broken rocker arm bolt
    Jun 2011
    Quote Originally Posted by gtpeddie View Post
    It didn't ... About 8 times.
  6. #6 Re: Broken rocker arm bolt
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Maybe there isn't red locktite on there. Could try an extractor before drilling at it.
  7. #7 Re: Broken rocker arm bolt
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    You said you put 105# springs in a week earlier......what rocker arm bolts did you end up using?
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  8. #8 Re: Broken rocker arm bolt
    Jun 2011
    When this happened to Me, Josh, Anmar, and Brandon, all I can say, is have fun.
  9. #9 Re: Broken rocker arm bolt
    Grand Rapids, MI
    us=
  10. #10 Re: Broken rocker arm bolt
    May 2012
    Fort Campbell, ky
    I already new it is going to be a pain, well I guess I'll know what I'll be doing this weekend instead of tuning for the 60lb injectors I have laying in the garage. And I thought I ordered comp cam bolts but when they arrived it was oem bolts. I thought they would be fine. I already placed an order for comp cam bolts though
  11. #11 Re: Broken rocker arm bolt
    Grand Rapids, MI
    the bolt that broke on us was a comp cam bolt
  12. #12 Re: Broken rocker arm bolt
    May 2012
    Fort Campbell, ky
    Great so I'm just screwed either way
  13. #13 Re: Broken rocker arm bolt
    Jun 2011
    Your not going to want to hear this but you will prolly be best off if you take the head off the car.
  14. #14 Re: Broken rocker arm bolt
    May 2012
    Fort Campbell, ky
    Quote Originally Posted by Iceman6669 View Post
    That's what I was wanting to avoid. I'm going to go ahead and try with it on and see what happens. Worst case I'll take it off
  15. #15 Re: Broken rocker arm bolt
    Jun 2011
    Well be careful with all the metal shavings.
  16. #16 Re: Broken rocker arm bolt
    May 2012
    Fort Campbell, ky
    Yeah I already thought about that. Going to grease everything to try and catch the shavings and cover and tape as much as I can
  17. #17 Re: Broken rocker arm bolt
    grease the drill bit good, and around that rocker bolt hole to catch the metal shavings.
  18. #18 Re: Broken rocker arm bolt
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Go buy a left hand drill bit. Heat the head around the bolt (not the bolt)
    You might get lucky and it'll back out.
    If not then buy a masonry drill and have fun. The masonry drill has a high speed carbide tip that will drill case hardened steel. It will drill through that bolt with no issues.
    Sent from Not so smart smartphone
  19. #19 Broken rocker arm bolt
    Mercer, Pa
    If there isn't loctite on the threads and the bolt isn't bottomed out in the hole you should be able to back it out. I use a vibrating engraving pencil to spin broken bolts out. Left hand drills work good to.
    I used grade 8 socket head cap screws.
  20. #20 Re: Broken rocker arm bolt
    hangover park IL
    OEM bolts have the threadlocker on the threads.....
    good luck.
    ~James~ Psychotic Gearhead
  1. Broken bolt HELP
    By MGRead in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-08-2013, 11:18 PM
  2. Rocker bolt help!!!!
    By DaytonaGTP500 in forum General Tech Discussion
    Last Post: 06-12-2012, 03:00 AM
  3. Best way to remove broken bolt
    By tms8582 in forum Brakes/Suspension/Chassis
    Last Post: 12-14-2011, 02:48 PM
  4. Broken rocker pediastal OK to install with 1.9's?
    By txslow6 in forum General Tech Discussion
    Last Post: 09-16-2011, 09:58 PM
  5. Broken bolt.
    By fri3dchick3n in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2011, 05:52 PM
