Thread: Question regarding the "DRL warning cancellor" capacitors
Results 1 to 19 of 19
  1. #1 Re: Question regarding the "DRL warning cancellor" capacitors
    Most people disable the DRL's based on info on the site. Not sure your year ..and I don't like Giant Piles anyhow..so I never looked into disabling it.
  2. #2 Re: Question regarding the "DRL warning cancellor" capacitors
    Jul 2010
    Coquitlam,BC,Canada
    Are these things supposed to just protect your HIDs and have them still lit, or should they shut off the HIDs when in only DRL mode?
    Basically, they simulate the halogen bulbs still being there, thus fooling the car and turning off any warning lights. They also prevent "flicker" of the HID that some vehicles can have.
    You need to either:
    1) disable the DRL's
    2) hook DRL's to come on with full power
    3) hook up the HID harness to come on with the ignition, thus acting as DRL's (also requires disabling of the factory DRL's)
    I run HID's with a harness and disabled DRL's; all works just as it should.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Question regarding the "DRL warning cancellor" capacitors
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Quote Originally Posted by Bronco Boy View Post
    You need to either:
    so with the capacitors installed, will the HIDs be lit, or will they be off? Also, on a 2003, do I just remove the DRL fuse, or relay? and if so, will it throw a code?
  4. #4 Re: Question regarding the "DRL warning cancellor" capacitors
    Jul 2010
    Coquitlam,BC,Canada
    They will work as normal.
    On my '02, I removed the DRL fuse and the DRL module buzzed. I ended up putting a switch on the DRL module. You could also just un-plug the DRL module.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: Question regarding the "DRL warning cancellor" capacitors
    Jul 2010
    Coquitlam,BC,Canada
    DRL Bypass: DRL_Bypass
    Auto On (Sentinel) Modification: Alarm_Headlamp_Flash
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  2. quick question... is this the "temp sensor" on 95' gtp (pic included)
    By Falcons33 in forum General Tech Discussion
    Last Post: 04-23-2013, 05:41 PM
  3. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  4. Recall 07035 engine fire "warning"
    By chuckd98gtp in forum The Rant Forum
    Last Post: 07-06-2011, 01:35 PM
  5. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
