Thread: Question regarding the "DRL warning cancellor" capacitors
Results 1 to 19 of 19
  1. #1 Re: Question regarding the "DRL warning cancellor" capacitors
    Jul 2010
    Coquitlam,BC,Canada
    so with the capacitors installed, will the HIDs be lit, or will they be off?
    They will work as normal.
    Also, on a 2003, do I just remove the DRL fuse, or relay? and if so, will it throw a code?
    On my '02, I removed the DRL fuse and the DRL module buzzed. I ended up putting a switch on the DRL module. You could also just un-plug the DRL module.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  2. #2 Re: Question regarding the "DRL warning cancellor" capacitors
    Jul 2010
    Coquitlam,BC,Canada
    DRL Bypass: DRL_Bypass
    Auto On (Sentinel) Modification: Alarm_Headlamp_Flash
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  2. quick question... is this the "temp sensor" on 95' gtp (pic included)
    By Falcons33 in forum General Tech Discussion
    Last Post: 04-23-2013, 05:41 PM
  3. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  4. Recall 07035 engine fire "warning"
    By chuckd98gtp in forum The Rant Forum
    Last Post: 07-06-2011, 01:35 PM
  5. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
