Thread: Trunk not opening
Results 1 to 13 of 13
  1. #1 Trunk not opening
    Aug 2012
    Jackson, Michigan, United States
    I'm having a problem with my trunk not opening. When you hit the button on the key fob, or try to hit the button in the car, all you can hear is a click from the inside of the car like it is sending a signal to open the trunk, but it's not opening. Anyone have this problem? Oh it's a 2004 Comp G...
    Quincy, Mass
    I had this problem and found a broken wire in my harness by chance one day that was the culprit
    No more GP 04 Impala SS Indy:
  3. #3 Re: Trunk not opening
    Aug 2012
    Are you talking about the wires right under the trunk lid?
    Quincy, Mass
    Nope mine was the wire going through the firewall to the fuse box. It was just by chance that I had found it. Your best bet is to find out which wire is shorted by test with a multimeter or even just a test light.
  5. #5 Re: Trunk not opening
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    Check the fuse. Mine did this when the fuse blew.
    Quincy, Mass
    When the fuse blows you won't have back up lights either
  7. #7 Re: Trunk not opening
    Aug 2012
    The fuse is good and my reverse lights work. I'm going to do some more looking around this weekend when I have spare time...
  8. #8 Re: Trunk not opening
    Derp RALM's Avatar
    Aug 2012
    Brandon, South Dakota
    Can you still open it with the Key?
    1995 Grand Prix SE 3.1L V6 N/A
    216,000 Miles
    1998 Grand Prix GT 3.8L V6 N/A 211,000 Miles (RIP)
  9. #9 Re: Trunk not opening
    Aug 2012
    I have one of the oddballs that didn't have a keyhole for the trunk...
  10. #10 Re: Trunk not opening
    looks like you need to take the back seat out and crawl in the trunk to jimmy the lock and open it up and check all the wires. 2 bolts at the lock latch comes off and the trunk opens up. 10 mm i think.
    it used to work, right?
    edit: the lock actuator could have gone bad too. the thing that pops the trunk.
  11. #11 Re: Trunk not opening
    Aug 2012
    Work*
  12. #12 Re: Trunk not opening
    Aug 2012
    Yes it it did workg
    Derp RALM's Avatar
    Aug 2012
    Quote Originally Posted by balt1024 View Post
    Yes it it did workg
    Good to hear
    216,000 Miles
  1. I'm pretty sure hitting big bumps is opening my trunk..
    By GTLGDP in forum General Tech Discussion
    Last Post: 01-22-2012, 08:09 PM
  2. Opening the can of worms.
    By Cail in forum Introductions/Noob Questions
    Last Post: 09-03-2010, 06:03 AM
  3. Trunk not opening at all
    By bigboibbp in forum Audio, Security & Visual Electronics
    Last Post: 08-16-2010, 06:22 AM
  4. Opening a door
    By speedracer88 in forum General Tech Discussion
    Last Post: 03-19-2009, 03:28 PM
  5. is my thermostat not opening?
    By nemesis in forum General Tech Discussion
    Last Post: 10-25-2008, 07:16 PM
