Thread: HIDS interfering with radio
Results 1 to 12 of 12
  1. #1 HIDS interfering with radio
    SE Level Member skylar44's Avatar
    Jul 2012
    Toronto
    so I just noticed this a couple weeks ago (have had HIDs for months) but now that I live far from most radio stations that it causes some static, this has become apparent. When I turn my HIDs on the radio turns to almost full static and when they're off it's completely fine. What's happening?
  2. #2 Re: HIDS interfering with radio
    Nov 2008
    Waterloo, Iowa
    Do you have an aftermarket deck?
  3. #3 Re: HIDS interfering with radio
    Jul 2012
    Toronto
    nope
  4. #4 Re: HIDS interfering with radio
    find better grounds for the lights.
  5. #5 Re: HIDS interfering with radio
    Nov 2008
    Waterloo, Iowa
    pretty much the issue. if you're not using a relay harness, use one. otherwise, ground them in a better spot.
  6. #6 Re: HIDS interfering with radio
    Jul 2012
    Toronto
    where should I ground them?
  7. #7 Re: HIDS interfering with radio
    Antioch, IL
    radiator support/fender bolt. take a bolt out sand it down to metal, reassemble.
    2009 Challenger SRT8
    Expert at being gay.
  8. #8 Re: HIDS interfering with radio
    some where that there's no paint. you need bare metal for a solid ground.
    or take them off and sand where they are now, till bare metal. bolt them back up.
    also make sure your ground straps are in place by the battery to body. they keep the whole car grounded, its just a wire, nothing like a battery cable.
    and of course double check all of the wiring from the install. and then last but not least take them off and put back the stock lights, and see if the problem goes away. for all you know its still there and your chasing a bad FM signal.
    XM rules btw. ive had it for like 7 years now, cant live with out it now.
  9. #9 Re: HIDS interfering with radio
    Jul 2012
    Toronto
    could it be because of my overkill pcm? seemed to happen around the same time
  10. #10 Re: HIDS interfering with radio
    i dont think the tune has nothing to do with it.
    popping them out and going back stock cant hurt for a while, just to see it its still there, you also moved out of range some you said.
  11. #11 Re: HIDS interfering with radio
    Jul 2012
    Toronto
    dont know if I still have my stock bulbs, gotta go digging or they might be at home (at uni now). Back home (Toronto) I noticed that stations in hamilton region that I used to get became static but toronto stations were fine, now in Waterloo everything is static if I have my HIDs on.
  12. #12 Re: HIDS interfering with radio
    in that case check the wiring over and the grounds. they must be related.
    i would think if you just unplug them and turn on the lights, and radio, see if it clears up any like that.
    even with out the bulbs that should narrow it down to the hid's. or not.
  1. Fog HIDs
    By DEEGZ in forum 5.3L V8 (LS4)
    Last Post: 05-19-2011, 09:00 AM
  2. Those who have HIDS
    By trenaro in forum Visual/Body Modifications
    Last Post: 12-05-2010, 06:51 PM
  3. HIDs on a 05'
    By tayl5645 in forum Visual/Body Modifications
    Last Post: 07-22-2010, 07:34 PM
  4. H3C Hids
    By Slueth66 in forum Visual/Body Modifications
    Last Post: 01-20-2010, 12:59 AM
