there is alot of money into ths setup now, way too much. but you can use a spec stage 3+ and make 500whp no problem with the right mods,
update again
intermediate shaft to engine block mount, triangulated, this will be excellent.
ready for powder
the trans mount is wraped around the subframe in a U shape, hes a few more pics.
clutch slave lines ran, you can see the gromet for the one line, the other will be going through the inspecton cover which is made of rubber aswell
i made this bracket to keep the release bearing from spinnig on the base, on the top ill be using a P clup to keep the braided line down thats why its not tightened yet.
engine and trans will be bolted onto the subframe tomorrow and may get put in the car if i get the chance.
