First, I never called you a troll, I said I wasnt going to "start ****" in case you were just baiting someone out. Prepare to get owned:
Ok, First off, headers will decrease your exhaust energy going to the rear, creating lower spool. Second headers would never increase power, because well there is over 1.5x the pressure in your exhaust, than what is in your intake side on any turbo setup.Ever tried a rear mount turbo? I mean you could run some nice headers and have an get a even cooler charge entering the motor
The "cooler charge" idea is also dumb, because after pushing air through a maze of tubes over that long of a distance, the turbo is going to have to work harder to get the same amount of air to the front, which will increase the temperature of said air. An intercooler in ANY turbo setup would have a massive cooling property compared to any "long series of tubes".
"boost drop" does not exist, due to the fact that you pick what boost you want to see at the intake manifold. Any "drop" you may see is going to be caused by resistance via surface tension or turbulence. "lag" is created by the fact that your exhaust has lost 20-40% of its energy by the time it has gotten back to the turbo., is the boost drop the problem or just too much lag?
The trans is not mounted yet..And you got any closer pics of the custom trans mount on there?
I am really confused by this... I dont see why you would want to do a manual, as the fact that it cost well more than double what a built auto would, and you would still have to install it.... The clutch alone in this car cost what a built trans costs, and probably much more.I see your car and really consider just spending the 2-3k I need for a bulletproof automatic and do the manual swap instead and have more fun with it...lol
