Thread: ....you know what it is... 700whp build
Page 9 of 14 FirstFirst ... 7891011 ... LastLast
Results 161 to 180 of 274
  1. #1 Re: ....you know what it is... 700whp build
    michigan
    This build is so bad ass and makes me so envious! I wish u the best of luck man!
  2. #2 Re: ....you know what it is... 700whp build
    SE Level Member AWeb80's Avatar
    May 2011
    Nebraska
    just finished reading through this thread....lots of hate.
    good luck Jeff, can't wait to see it finished.
  3. #3 Re: ....you know what it is... 700whp build
    Grand Island, Nebraska
    900WHP would be a record i believe.
    Maybe you will be the first to explode the bottom end...
  4. #4 Re: ....you know what it is... 700whp build
    GT Level Member GtpKo's Avatar
    Best place on Earth
    I still can't wrap my head around having more than 500hp in a grand prix.
    Fastest car I've ever driven was somewhere in the 350 range IIRC?. Long time ago but a friend was crazy enough to let me drive his 69.5 camaro, I'll never forget giving a Viper a run for his money across the Coronado bridge in SanDiego.
    2002 GT F23 5-speed swapped, SPEC stage 2+ clutch, ZZP Power Logs, E-brake handle swap.
  5. #5 Re: ....you know what it is... 700whp build
    I cant even imagine 400 hp. Fastest car ive driven was a cobalt ss and the fastest ive ridden in was a 2000+ z28.
  6. #6 Re: ....you know what it is... 700whp build
    michigan
    Quote Originally Posted by JoRoW99 View Post
    Lmao, really? You live in a very slow world my friend.
  7. #7 Re: ....you know what it is... 700whp build
    North Jersey
    ive been in a 610whp evo a few times. thing was built to be a 42psi Daily driver... that was scary fast.
  8. #8 Re: ....you know what it is... 700whp build
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Quad whp digits or bust.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  9. #9 Re: ....you know what it is... 700whp build
    I live here. UR LOSN's Avatar
    Rockford, IL
    keep up the good work! more pics?
  10. #10 Re: ....you know what it is... 700whp build
    Yes i do :'(
    duh i drive a GP
  11. #11 Re: ....you know what it is... 700whp build
    Feb 2009
    flintnasty MI
    I daily drove 400whp+ in a 10 second fiero for the last few years... Its not fast.
  12. #12 Re: ....you know what it is... 700whp build
    Waukesha, WI
    swap in a turbo LS1 in the fiero, that should be fast. right?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  13. #13 Re: ....you know what it is... 700whp build
    Quincy, Mass
    Quote Originally Posted by redlinepontiac View Post
    turbo 3800 weighs less.
    No more GP 04 Impala SS Indy:
  14. #14 Re: ....you know what it is... 700whp build
    Jul 2010
    Houston, Texas, United States
    Nah ,try a twin turbo 572. That should do it.lol
  15. #15 Re: ....you know what it is... 700whp build
    GT Level Member RegalGS98s's Avatar
    NJ
    Lil late, but friend's Fiero that who knows how much money is in it had the LS1 in it, but figured out could go faster with the 3800 because it was lighter.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  16. #16 Re: ....you know what it is... 700whp build
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    Quote Originally Posted by RegalGS98s View Post
    the car is already xp cammed 3.8L l67
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  17. #17 Re: ....you know what it is... 700whp build
    Feb 2009
    flintnasty MI
    uh? Serious post? A LS1 is more than 80lbs lighter than a L67.
  18. #18 Re: ....you know what it is... 700whp build
    NJ
    Shoot, maybe it was the LT1 at the time. I was thinking to myself, the LS1 is aluminum, it should be lighter. It was probably about 10 years ago when he changed to the 3800. Though I almost thought there was a cast iron version of the LS1 people use on extreme builds cause he was going for crazy power over 1000hp.
  19. #19 Re: ....you know what it is... 700whp build
    not without
  20. #20 Re: ....you know what it is... 700whp build
    Feb 2009
    flintnasty MI
    There are 2 turbo LS1 fieros, both run high 12s if they dont break.
  1. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  2. New build.
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 05:44 PM
  3. $400 gtp build
    By heavyRfoot in forum General Tech Discussion
    Last Post: 03-13-2010, 01:29 AM
  4. New Build
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2010, 08:50 AM
  5. The Build...?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 11-04-2009, 07:35 PM
