Thread: 8* of KR with cam, 3.4, FS IC, 90# springs. Nothings adding up (attached HPT logs).
Results 1 to 20 of 59
  1. #1 Re: 8* of KR with cam, 3.4, FS IC, 90# springs. Nothings adding up (attached HPT logs
    hangover park IL
    Is the wb reading jiving with commanded afr?
    ~James~ Psychotic Gearhead
  2. #2 Re: 8* of KR with cam, 3.4, FS IC, 90# springs. Nothings adding up (attached HPT logs
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Quote Originally Posted by Turbocharged400sbc View Post
    Yes almost perfectly. PE mode after you figure in my Base AFR and my enrichers is about 10.5, my base alone is 11AFR. Cruising is 14.7 all the time.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  3. #3 Re: 8* of KR with cam, 3.4, FS IC, 90# springs. Nothings adding up (attached HPT logs
    Kemmerer, Wyoming
    You should be aiming for 11.5 10.5 is too rich
  1. E-bay header help pics attached
    By evand in forum General Grand Prix Discussion
    Last Post: 06-11-2013, 11:22 AM
  2. Stripped stud with lug still attached
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 08-29-2012, 04:31 PM
  3. New grilles and re-attached body moulding
    By macey43 in forum Visual/Body Modifications
    Last Post: 01-25-2011, 03:21 PM
  4. Replies: 40
    Last Post: 10-10-2010, 09:12 PM
  5. How to remove TB spacer, attached with RTV
    By 04CompG in forum General Tech Discussion
    Last Post: 06-21-2009, 03:22 PM
