Thread: How to remove TB spacer, attached with RTV
Results 1 to 7 of 7
  1. #1 How to remove TB spacer, attached with RTV
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    I've decided I want to get rid of my TB spacer. Theres just too much hesitation with everyone on if they are worth a **** or not. I put it on myself and used a nice amount of RTV to attached it. I go down to PRJ for a re-tune tomorrow and after that I'm not going to do anything to my car performance wise for a while. Is this going to be a pain in the ass to take off? Any tips?
    Thanks.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  2. #2 Re: How to remove TB spacer, attached with RTV
    GTP Level Member Scimmia's Avatar
    QCA, IA
    BFH?
    If it's already on, why not just leave it on. I can't see it hurting anything as long as it's not leaking or something.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: How to remove TB spacer, attached with RTV
    Feb 2008
    South Bend, IN
    I think BIO said they cause the rear head to heat up or something. Thats not the sole reason i want to take it off though. ive always been iffy about it.
  4. #4 Re: How to remove TB spacer, attached with RTV
    Banned - Busted For Scamming
    Feb 2009
    ive never had any problem with it. the only reason those holes are there are to warm up the tb for a cold start, to make it run better, they are only 1/4 inch holes. i have mine blocked and havent modified the side lim port either.
  5. #5 Re: How to remove TB spacer, attached with RTV
    it wont have much of an effect, but im not one to enjoy knowing that my rear head is running hotter than the front. the coolant going through the blower and throttle body is part of the flow that goes to the rear head.
  6. #6 Re: How to remove TB spacer, attached with RTV
    Chisel. 'Nuff said. That is how I took the TB off of my blower. Just be easy and pry that ****er off
  7. #7 Re: How to remove TB spacer, attached with RTV
    Moore, Oklahoma
    rubber mallet should do the trick...
    Shawn W. Larsen
  1. S/C spacer?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2009, 09:09 PM
  2. hole forming inside of the PCV housing attached to intake plenum.
    By Rick C in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-15-2009, 11:47 AM
  3. wood IC spacer
    By 04DetroitLS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2008, 05:25 PM
  4. TB spacer?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2008, 06:43 PM
